Pro4x shocks vs 4x4? - Nissan Titan Forum
post #1 of 4 (permalink) Old 11-20-2012, 12:43 AM Thread Starter
iTrader Score: 6 reviews
Which one is stiffer. And which is best for 2wd and why?
Aztec72 is offline
Advertisement
post #2 of 4 (permalink) Old 11-20-2012, 09:29 AM
jakejc's Avatar
iTrader Score: 4 reviews
The pro 4x are a lot stiffer so will give you more lift but it depends on the purpose you want them for
2010 4x4 Crew Cab Se Blizzard White
AEM Brute Force Cold Air, Rear Cat delete with 2.5" straight pipes in place, Dual in Dual out BORLA Turbo Xl muffler, BDGT regular tune W/2* timing advance, Prg upper control arms, Icon/Dr coil overs with 14" 650lb EIBACH coils, 5125's in rear, w/extended bump stops, 32" Led light bar pencil beam, 8000k hids high, low, and fog lights, Projector fog lights, custom mounted Kc's in lower grille hid converted 55w 6000k, custom mounted Kc's behind billet grille hid converted 55W 6000k,, black painted grille, Spyder halos with custom carbon fiber cover, Also with Custom mounted FXR 3.0 projectors in place of the crappy spyder ones 5% tint all around with a 35% windshield and vinyl blacked out taillights, color matched interior, color matched engine cover, Jvc headunit, 10"SKAR AUDIO Subs Forward Firing in an AMAZING TECH 12V ported box, powered by an audio pipe 1500w amp
jakejc is offline
post #3 of 4 (permalink) Old 11-22-2012, 09:06 PM Thread Starter
Re: Pro4x shocks vs 4x4?
Is the stiffness bad for the suspension
Aztec72 is offline
post #4 of 4 (permalink) Old 11-22-2012, 10:40 PM
osiris10012's Avatar
Garage
iTrader Score: 5 reviews
The stiffness is only bad for the ride quality. In all honesty I would look into getting a set of bilstein hd's or 5100's over oem nissan or the oem rancho (pro4x) struts/shocks. They will last much longer.
2006 Radiant Silver 4x4 CC LE
Performance: JBA Long Tube Headers, Cajun 2.5" Reso B Pipes, 2.5" to 3.0" CAJUN Y Pipe, TAP Auto Mid Pipe, Borla XR1 16" 40944, Spectre 4" Reso Tip, Vibrant UQ Reso, Uprev Tuned by Seymore4 and K&N Drop In Filter
Suspension: Rough Country 6" Lift, Bilstein 5100's (Middle Perch)/5125's, 1.5" PRG BL
Wheels: Fuel Maverick 20x12" with -44mm offset, Nitto Terra Grappler G2 325/60-20's
Audio: Sundown Audio E10, Mbquart1 Custom Harness, Precision Power BK1800.1D, Sky High Audio 1/0 gauge ofc wiring
Misc: Full Interior/Exterior LED's From LegitLED, TonnoPro TriFold Tonneau Cover, Cajun Axle Vent
osiris10012 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Trade pro4x shocks less than 5k Aztec72 Buy/Sell 7 12-12-2012 08:11 PM
is it OK to use pro4x shocks + non pro 4x4 springs? BlocksRocks Titan Suspension 4 10-19-2012 08:30 PM
**FEELER** Stock Pro4x Rancho Front Shocks cohunter14 Buy/Sell 5 03-05-2012 07:29 PM
WTB: Pro4x complete front shocks. ricepow Buy/Sell 2 12-30-2011 06:41 AM
PRO4X rear RANCO shocks 4sale mwg13090 Buy/Sell 2 12-10-2009 08:22 AM
You may post new threads
You may post replies
