What coil to replace my dr/icon coil - Nissan Titan Forum
Old 11-20-2012, 09:28 AM   #1 (permalink)
jakejc's Avatar
iTrader Score: 4 reviews
So I have my coilovers cranked full preload and even have the hats flipped and am not getting much lift for what's been done so I was thinking to replace the coil all together. What brand would you guys to with? I called king and there's are $84 a piece and they use a 3.0 on there 2.5 shocks. To get a new icon shock it's $74 and since in not the original owner of the shock they won't warranty my coils. I called fox and they don't sell directly. I need to call saw still and I was going to call eibach too. What do you guys suggest? Thanks
2010 4x4 Crew Cab Se Blizzard White
AEM Brute Force Cold Air, Rear Cat delete with 2.5" straight pipes in place, Dual in Dual out BORLA Turbo Xl muffler, BDGT regular tune W/2* timing advance, Prg upper control arms, Icon/Dr coil overs with 14" 650lb EIBACH coils, 5125's in rear, w/extended bump stops, 32" Led light bar pencil beam, 8000k hids high, low, and fog lights, Projector fog lights, custom mounted Kc's in lower grille hid converted 55w 6000k, custom mounted Kc's behind billet grille hid converted 55W 6000k,, black painted grille, Spyder halos with custom carbon fiber cover, Also with Custom mounted FXR 3.0 projectors in place of the crappy spyder ones 5% tint all around with a 35% windshield and vinyl blacked out taillights, color matched interior, color matched engine cover, Jvc headunit, 10"SKAR AUDIO Subs Forward Firing in an AMAZING TECH 12V ported box, powered by an audio pipe 1500w amp
jakejc is offline   Reply With Quote
Advertisement
Old 11-20-2012, 09:47 AM   #2 (permalink)
jakejc's Avatar
What coil to replace my dr/icon coil-imageuploadedbyautoguide1353433563.626807.jpg
$129 for 14" 2.5 king coils 650lb rating
Old 11-20-2012, 10:00 AM   #3 (permalink)
DRTYAZN's Avatar
iTrader Score: 12 reviews
Re: What coil to replace my dr/icon coil
I recommend Eibach Coils, Eibach is in SoCal and they can be purchased through a lot of vendors, check their website for vendor referrals... If you're 4X, I recommend 650 or 700 lb coils, but if you're 2X, you'll be fine with 600 or 650...
DrtyAzn
Slightly Modified 4X4 '06 Titan CC
DRTYAZN is offline   Reply With Quote
Old 11-20-2012, 10:04 AM   #4 (permalink)
jakejc's Avatar
im just se 4x4 and the highest all the coils i find go up to 650lb I found a set of eibach coils for $120 on Poly Performance and love the price ha
Old 11-20-2012, 10:06 AM   #5 (permalink)
jakejc's Avatar
the kings are only $10 more than eibach so far the saws are the most expensive
Old 11-20-2012, 10:13 AM   #6 (permalink)
DRTYAZN's Avatar
Looks like 650 lb is highest rating in 14"x3" coils... but this past April, I had spoken with Eibach directly and they were in the process of manufacturing 14/3/700 coil springs but don't know if they ever did or not... You could try and call or email them about it as well...
DrtyAzn
Old 11-20-2012, 10:15 AM   #7 (permalink)
jakejc's Avatar
can i fit 3" coils in my 2.5Dr coil overs
Old 11-20-2012, 10:18 AM   #8 (permalink)
jakejc's Avatar
going to the 3.0 it bumps the eibach up to $190
Old 11-20-2012, 10:33 AM   #9 (permalink)
DRTYAZN's Avatar
Our front shocks are 2.5" diameter, and the coils are 3" ID (interior diameter) to allow no contact... so, Yes, you'll need 3" coils, 2.5" coils won't work too well... Jake, PM me with your #... I might have a set of almost new 14/3/650 Eibach coils for ya at a great price...
DrtyAzn
Old 11-20-2012, 10:39 AM   #10 (permalink)
jakejc's Avatar
sweet man thanks pm sent
Advertisement
Coil overs nismojunky Titan Suspension 4 12-23-2011 04:19 AM
4x4 coil height vs 2x4 coil hight HVFC6040 Titan Suspension 41 12-21-2011 08:35 PM
08+ coil buckets USN HM 350Z Titan Suspension 8 01-03-2011 03:08 PM
Is a Broken Spring on DR/Icon/King Coil-overs Common? thebassn8tr Titan Suspension 7 09-23-2010 03:29 PM
Coil-overs??? pisswilly Titan Suspension 16 12-06-2004 11:44 AM
SEO by vBSEO 3.3.2
