Help-My daily driver is taken apart and I need a hand! Leveling kit.... - Nissan Titan Forum
Old 01-13-2013, 04:11 PM   #1 (permalink)
iTrader Score: 0 reviews
Exclamation Help-My daily driver is taken apart and I need a hand! Leveling kit....
My T is a 2006 4x4 and I'm trying to install a 2.5" leveling kit.
I know that pushes the limit for CBC, but here's the thing-I ground off the lip on one of my coil buckets and I still can't get the bottom of the strut to fit back in.
My real problem at this point is that I have no idea how I'm going to "persuade" the bottom of the strut assembly to get back where it belongs. I had a hell of a time getting the sway bar disconnected-that took me literally hours. I love Wisconsin salt on the bolts exposed to it....
Does anybody have any helpful hints? I would really appreciate some guidance here. I already tried unhooking the UCA and then jacking up the lower suspension to meet it. My truck nearly fell off the jackstands b/c with the strut in place the whole truck comes up....
Help?!
http://imageshack.us/photo/my-images/811/picture013vx.jpg/
2006 CC Titan XE 4x4
Mods so far: Bully Dog Power Pup Tuned, 2.5" Leveling Kit, airbox mod, Spec-D projector headlights, smoked altezza tail lights, soft tonneau, nerf bars, Plasti-Dipped bumpers and grille insert, bedlinered wheels.
Parts waiting for a home: Front window tint, custom exhaust, trailer hitch, some leftover bedliner I might throw on the...BED?
Stuff to do later? MXP, HID lows.
Evillseed is offline   Reply With Quote
Advertisement
Old 01-13-2013, 04:17 PM   #2 (permalink)
jtrick's Avatar
iTrader Score: 5 reviews
You don't need to mess with the swaybar. You will jack the lca up to get the uca and spindle to reconnect. It's not uncommon for the truck to come off the stands. Good luck.
Sent from my T
2008 Crew Cab 2WD
2.5" Front, 1.5" Rear Lift
Billstein 5100's on Middle Perch
PRG Extended Endlinks
2" Wheel Adapters
BDGT Tuned with RAM Mount
Airraid MXP CAI
Flowmaster Exhaust
275/70R/18 Nitto Terra Grapplers
Bedlined Everything
Legit 8k High and Low HIDS
Legit Blue interior LED package
20% Tinted Front Windows
jtrick is offline   Reply With Quote
Old 01-13-2013, 04:27 PM   #3 (permalink)
Re: Help-My daily driver is taken apart and I need a hand! Leveling kit....
Sent from my T
So you're saying to disconnect the uca ball joint, put the strut in and then jack up the lca to bolt them back up?
thing is, my truck didn't almost LIFT off the stands, It almost FELL off the stands lol.
I'll give that another try.
In the meantime any other suggestions are welcome.
Old 01-13-2013, 04:29 PM   #4 (permalink)
kmr481's Avatar
iTrader Score: 2 reviews
Try prying down on the lca and tapping the shock into place. I had an issue with mine where some of the metal in the lower mount got mangled up, had the grind a little.
Sent from my DROID RAZR using AutoGuide.Com Free App
kmr481 is offline   Reply With Quote
Old 01-13-2013, 04:30 PM   #5 (permalink)
iTrader Score: 1 reviews
I'm running a 2.5 on my 06 and
Sent from my iPhone using AutoGuide.com Free App
trivo is offline   Reply With Quote
Old 01-13-2013, 04:30 PM   #6 (permalink)
No issues or
Old 01-13-2013, 04:31 PM   #7 (permalink)
kmr481's Avatar
Yeah jack it up to reconnect, you'll have to pry down on the uca to get the nut started on the upper ball joint
Old 01-13-2013, 04:35 PM   #8 (permalink)
jakejc's Avatar
iTrader Score: 4 reviews
when i used my 2" spacer and 5100's i had to jack the truck up a good bit to get the shock to compress to have everything meet
2010 4x4 Crew Cab Se Blizzard White
AEM Brute Force Cold Air, Rear Cat delete with 2.5" straight pipes in place, Dual in Dual out BORLA Turbo Xl muffler, BDGT regular tune W/2* timing advance, Prg upper control arms, Icon/Dr coil overs with 14" 650lb EIBACH coils, 5125's in rear, w/extended bump stops, 32" Led light bar pencil beam, 8000k hids high, low, and fog lights, Projector fog lights, custom mounted Kc's in lower grille hid converted 55w 6000k, custom mounted Kc's behind billet grille hid converted 55W 6000k,, black painted grille, Spyder halos with custom carbon fiber cover, Also with Custom mounted FXR 3.0 projectors in place of the crappy spyder ones 5% tint all around with a 35% windshield and vinyl blacked out taillights, color matched interior, color matched engine cover, Jvc headunit, 10"SKAR AUDIO Subs Forward Firing in an AMAZING TECH 12V ported box, powered by an audio pipe 1500w amp
jakejc is offline   Reply With Quote
Old 01-13-2013, 04:44 PM   #9 (permalink)
beason's Avatar
iTrader Score: 9 reviews
Send a message via AIM to beason Send a message via MSN to beason Send a message via Yahoo to beason
yea the UCA bushing makes it kind of springy. pull down on it, after you get all the weight of the truck on the jack on the lower. A second set of hands may help.
Ever growing mod list here
WhinyWhore™
Originally Posted by The Urinator™
before flapping your feed trap use your think blob
beason is offline   Reply With Quote
Old 01-14-2013, 09:17 AM   #10 (permalink)
kmr481's Avatar
You get this thing back together or what??? Oh and don't forget the before and after pics
Old 01-15-2013, 10:13 AM   #11 (permalink)
Thanks for the advice guys. Sorry for not updating but I went back out there and got my arse to work-had to be driveable by Monday morning, ya know!
For whatever reason the first jack that I was using was not letting the LCA articulate (move up) and the whole truck was getting jacked up while the LCA stayed put. Then the jack basically slipped off and I got scared when the truck fell an inch or two onto the jack stands. Nearly had a Titan in my lap, which would have been bad for both of us.
So, being scared, I pulled the lower strut mount back apart and started trying to get the UCA and LCA both bolted in without jacking the LCA and hub up. This was the wrong call. I spent a hell of along time trying to get that lower strut back in place, including ratchet straps to pull the strut toward the mount on the frame (which actually got kind of close but still a bad idea). jtrick has it right-and after reading his advice I grabbed a different jack and for whatever reason it worked. I put the strut in, jacked the LCA up and screwed the spindle back on. Still had to use a little of my ample manliness to push the UCA down to make the connection but it worked fine.
I have a before pic, no afters yet but it's 100% better. I'm very happy with the mod. The 2.5" worked fine on my '06 4x4, with the caveat that I do get CBC on the side that I did not yet grind down. I'll need to fix that sometime, but the only time I get CBC is over speed bumps. Regular roads cause no trouble at all. I seldom go off-roading but that would cause CBC too, I'm sure.
I'm really surprised at how much the leveling affects driving position and positively so. I feel like I can see better and that my arse is further back in the seat as opposed to tipped forward. Honestly makes the truck feel bigger too-reminds you of driving a 3/4 ton or Super Duty. For shorter people this could actually be a bad thing, but I dig it.
My kit was one of the $57 generic billet ones off of eBay. It seems sturdy and I'd recommend it for bang for the buck. The height of my truck from floor to fender at the center of the hub went from about 36.5 to about 39, so the 2.5 inches was right on and the spacer was roughly 1 7/8 or so tall.
Pics will come up soon. Before is basically in my signature but I'll get afters up.
Thanks very much to everybody who helped me out-this would have been a really bad deal without good advice from you all. Thanks, TT!
The Following User Says Thank You to Evillseed For This Useful Post:
kmr481 (01-15-2013)
Advertisement
Should I Buy a Daily Driver! Stilltime Off-Topic Discussion 16 11-19-2012 07:02 PM
My T becoming my daily driver. kmr481 Titan General Discussion 12 10-24-2012 02:17 AM
Daily Driver Prerunner help Pengy Titan Suspension 149 06-18-2010 09:21 PM
3.73 or 4.11 for a daily driver? MrStevie Titan Engine, Transmission & Drivetrain 10 10-10-2009 09:41 AM
is your titan your daily driver? C4RACER Titan General Discussion 48 05-26-2007 09:19 PM
SEO by vBSEO 3.3.2
