hello. New member here. Long time ford owner turned titan owner. Tired of those darn ford transmissions lol. Anyways i have always had lifted trucks, and am inclined enough to install lifts, lowering kits etc...
With that beibg said, i wanted to get your opion on a lift setup i want to run on my 20055 titan 2wd SE CC. This is what setup i want to do...let me know if u think it will work or not.
Rough country 6" lift
08 4x4 front coils
Bilsteins on middle perch
Rough country upper control arms.
Of course the rear will be rough countrys supplied 5" block, will install carrier bearing bracket.
What amount of lift do u guys think ill be looking at? Will this be enough to clear 37's? Am i going to run into coil bucket contact, or have issues installing the strut assembly backup? Any help is appreciated, thanks alot.
Just helped my buddy do a 6" on his I would recommend spending a little extra and get a fabtech its a much better lift for just a couple dollars more he is 4x4 he could fit 37,s
To the OP,, whats your location??? Hit up member Citadel,, He is looking to go back to stock.
07 4X4 CC LE BT OR
2.5" Leveling Kit
2010 LE 20's
Nismo CAI
JBA Ceramic LTs
UpREv Tuned
2.5" SS Catted Cajun B-Pipes
18" Magnaflow swap
Airlift Airbags
20% Tint
Headlight mod
Armaden LED interior
You might be able to squeeze 37's. idk. The pwm will
Be needed. And a non aggressive offset. Otherwise prg has a 1.5" body lift that'll prolly give you the needed space. And it doesn't show frame rails at all.
__________________ 2011 White CC pro4x
Flowmaster Y
Banks Muffler
Airaid MXP 4" Intake
PRG UCA's
Extended travel Sway-Away 2.5 coilovers
PRG Camber Bolts
Homemade Traction Bars
Fuel Boost 18x9
Nitto Terra Grapplers 295/70 18
Front BORA 1.25 Wheel Adapters/ Pinch Weld Mod
6K HID's
10" Sub/Kenwood Amp
also agree on spending the extra $$ on fabtech... i had an 8in cst (which is about 6"1/2 of lift) 3in body lift and coilovers and honestly... 37/38s woulda fit, but without my 3in body lift i dont think they would have......
i would go with 4" spindles, a 2" leveling kit, 4x4 springs, 5100's on middle. probably get 9" of lift. cheaper and easier install.
'05 Titan SE CC 2WD
5100's(middlenotch)
CST Spindles
2.5 leveling kit
35X12.5X18 BFG KM2's
Debadged
2 degree timing advance
Air Box Mod
Mesh Grille Mod
Headlight Mod
Homemade Tow Hooks
The Following User Says Thank You to TITANBOY For This Useful Post:
Is there any actual "no cutting to install" 6" lift for the T??
07 4X4 CC LE BT OR
2.5" Leveling Kit
2010 LE 20's
Nismo CAI
JBA Ceramic LTs
UpREv Tuned
18" Magnaflow swap
Airlift Airbags
20% Tint
Headlight mod
2007 4x4 SE CC BT UpRev Tuned W/ TLPM
S&B CAI W/ 4" Ram Air & DEI Cooltape|Bosch Platinum IR Fusion Plugs|3"x26" Maggy to shut it up
PRG UCA's|PRG Heimed Outter Steering|Bilstein 5100's & 5125's|08 4x4 Coils|1.5" Spacer|C-10 Deavers|315/70/17 BFG's
PRG Traction Bars|eBay Grille|UWS LoPro|Headlight Mod|Tinted Tails|Colormatched Mirrors & Handles
15% Tint All Around|Wet Okole's|WeatherTech Digital Fit Mats|Custom Rear Storage The Stigs Mechanic
Your ride would be insanely stiff with a 2wd; you don't have the weight of the transfer case or front diff to balance out the 4wd springs. 4" spindles, 2" spacer, current coils on middle would be more firm than stock, but not harsh, and still plenty of height (7"-8")
I know, that's what I have. The ride is not stiff at all. Many 2wd have the 4x4 springs on the middle. The op is trying to clear 37's not gonna do it with 7-8"
'05 Titan SE CC 2WD
5100's(middlenotch)
CST Spindles
2.5 leveling kit
Debadged
Air Box Mod
Mesh Grille Mod
Headlight Mod
Homemade Tow Hooks
