Old 09-21-2004, 12:58 PM   #1 (permalink)
morpheoussc400's Avatar
Send a message via Yahoo to morpheoussc400
How About a rear drop?
Now I know there are a lot a guys and gals who are all into lifting the truck to the heavens so you could cross a lake without the water reaching your floor pan, but I'm not interested in that. My truck will probably never see the mud or dirt (well maybe sand on the beach) while I'm still paying for it. So I was wondering if anyone knew of a good rear drop that levels the truck off instead of a front lift.....
[FONT=Comic Sans MS]undefined[/FONT][SIZE=5]undefined[/SIZE]undefinedMike L.
morpheoussc400 is offline   Reply With Quote
Old 09-26-2004, 11:44 AM   #2 (permalink)
Titano24's's Avatar
Send a message via AIM to Titano24's
i want the same thing
-Shane
2004 CC 4x2 Titan LE (White)
Engine : AEM Brute Force, Airraid TBS, TB Coolent bypass, Deleted Resenators, Banks Monster Exhaust
Looks : 22" Giovanna Aburzzo's, 20% Tint, Painted Armada Front Lip, Truxedo Lo-Pro Bed Cover, 2" Rear drop, In-channel Vent Visors, OEM bugshield
Entertainment : Kenwood DDX-7015, JL Audio 1000/1, JL Audio 450/4, JL XR 6.5 Components, 2 x JL Audio 8"w7's, Audiocontrol 6XS, Kinetik 2000 and 800 batteries, *coming soon Iraggi 220amp alternator*
Titano24's is offline   Reply With Quote
Old 09-26-2004, 01:06 PM   #3 (permalink)
CharlienoX's Avatar
ditto.
I've had spring shops pull the pack and re-arch them in the past (to the desired level), but this truck is a wee bit pricey and I'm unsure if this would have negative effects or not. I think for now it will remain stock...
Pulling the load leaf isn't an option for me as I intend to use it as a truck (hauling towing, etc...). If you don't intend to put weight in the back or tow with it, removing the load leaf will drop it a bit and smooth out the ride considerably. You would want to make sure you wouldn't bottom out the shocks and check a few other things, but that would be one way to do it (very low-buck mod).
CharlienoX is offline   Reply With Quote
Old 09-26-2004, 10:03 PM   #4 (permalink)
dersheist's Avatar
I heard shackles are are also a small expense option that moves the position of the leaf springs to lower the rear end 1 or 2 inches. Since it takes 2 1/2 inches to raise the front to be level, a 2" drop in the rear is also what I'm looking for. I believe shackles are designed for certain vehicles, and I haven't found any for the Titan yet.
Anyone hears anything different let me know.
06 Titan LE CrewCab 4x2 - Smoke
275/60 tires on 20x8.5 rims
Nissan chrome step rails
SIRIUS
dersheist is offline   Reply With Quote
Old 12-18-2004, 07:59 PM   #5 (permalink)
Send a message via AIM to Pete6923
Chassis Tech Makes a 2" drop shackle for the Nissan Titan for 69.99. I am Actually picking my kit up on Monday 12/20 .. I was told that the new shackles might barely hit the bottome of the bed, there is a 2 1/2 inch clearence from the existing bracket to the bottom of the bed. I will let youGuys know If it works ..
Pete6923 is offline   Reply With Quote
Old 12-19-2004, 08:49 AM   #6 (permalink)
I'm thinking of ordering an extra set of shackles and taking them to a machine shop and have them extended about an 1 1/2 inches . That's about the max you can go without doing some cutting under the bed. That and the helper springs will give me about a 2 inch drop. Shackles are about 10 bucks apiece plus the machine shop labor. Shouldn't be too costly.
Herbpov is offline   Reply With Quote
Old 12-19-2004, 10:49 AM   #7 (permalink)
Who's shackles were you going to order ? I would like to do the same thing.
TOTitan is offline   Reply With Quote
Old 12-19-2004, 10:59 AM   #8 (permalink)
I'm going to order the stock ones from nissan dealer and have them extended. I talked to a guy from a machine shop and he said he could do and they would look just like stock except longer.
Old 12-19-2004, 11:03 AM   #9 (permalink)
If you look above the rear shackle you will see a lip about 1 inch long that is under the bed which could be ground down a little without hurting anything if you want to gain a little more room.
Old 12-19-2004, 11:05 AM   #10 (permalink)
Cool...thanks for the info. I think I'll try it.
Old 12-19-2004, 11:08 AM   #11 (permalink)
Should be a pretty inexpensive drop. I should have about $50.00 wrapped up in it.
Old 12-20-2004, 07:40 PM   #12 (permalink)
I went to Chassis tech here in Mesa AZ, They now said they are no longer making the shackels,
Old 12-21-2004, 08:31 PM   #13 (permalink)
Just finished measuring everything up and it looks like I'm going to get about 1 1/2 inch drop with the modified shackles and 1/2 inch drop with the helper springs (JETTECH) so I should have about a 2 inch drop at the back bumper.
The rear wheel opening will be about 1 inch greater then the front. This should allow me to haul about 500 lbs in the rear without the rear being lower than the front. Just waiting for my shackles to come in now.
Old 12-28-2004, 03:11 PM   #14 (permalink)
Just finished installing the modified shackles with were extended 2 inches. I got a two inch drop at the back bumper. I have a 5 inch opening in the front wheel well and a 6 inch opening in the rear wheel well. I also have the helper springs installed. I got just the look I wanted. Total cost was about $35 dollars. If you wanted a little more drop you could extend the shackles up to 2 inches but you would have to grind about 1/2 inch off of that lip that is on the bottom of the bed.
Old 12-28-2004, 04:01 PM   #15 (permalink)
Titano24's's Avatar
Can you post pics and maybe a list of total cost and where to get the items for this drop from?
-Shane
