Old 06-14-2004, 12:55 AM   #1 (permalink)
Ok, so dayfart 2.5 kit causes breakage... Now what...
Hello, new here. I love my new truck. I cannot stand the "raked" look.
I searched all the threads. Thank you 1badtitan for saving me a headache. I was about to pick up this kit until I read your experience. I don't know why I thought that 2.5 inches of pre-load on these struts wouldn't have a negative impact.
Yeah, I don't know what gives with all the major truck makers these days. I wish that I could talk to their engineers. WE DON'T WANT THE TRUCK TO SIT 2.5 INCHES LOWER IN THE FRONT - MORONS! Nissan gave me everything I was looking for - except for this. If you engineers need to compensate for towing... INSTALL A 300.00 PNEUMATIC LEVELER AS AN OPTION... (Rant mode off)
Well, what are my other options. I wan't a level truck, but I don't want to destroy the suspension, CV joints, or my warranty. Frustrating... Does anyone out there make a good, solid, permanent solution. I guess 100.00 bucks from Daystar, you get what you pay for.
BossHogg is offline   Reply With Quote
Old 06-14-2004, 08:57 AM   #2 (permalink)
Amen bro. I also want to level out the front of my 4x4. I don't want a huge lift or bigger tires that kills the mileage. I just want it level. I almost bought a datstar off of ebay. Thankfully I found this forum before I did. Why can't somone just make a front body lift or something? Our trucks are new to the world. I think with time and patience somebody will eventually make something that will work for us...
2004 Canteen Titan XE CC 4x4 Off Road. Receiver hitch, bed extender, K&N filter. No Big Tow.
Arkytitan is offline   Reply With Quote
Old 06-14-2004, 09:21 AM   #3 (permalink)
I understand for your use the problems that the rake causes however for
people like me who haul weight and tow the truck levels right out in these
situations. Air bags and air lines tend to fail after extended gravel road use
and they limit rear wheel articulation sometimes. So I don't think they are
morons they just built a truck to be safe and level with a load. It is a truck
you know people use them for doing work and a level ride when loaded is
important. Just thought you should hear from the other side. It was easier
on the previous Nissan truck as all you had to do it crank the bars in the
front up a little. Give it time and someone will come up with an answer
for you. It takes a little while for the aftermarket to get things out and as
you have seen you don't want the first stuff that is out. Sometimes I think
they should offer two types of suspensions. One for the street level and
with a lower weight rating and a heavier duty one for people like me that
way we can both be happy. I don't want airbags and hoses. Already done
that multiple times and while it is a good solution for some people I have had
nothing but trouble.
Zardoz
Zardoz is offline   Reply With Quote
Old 06-14-2004, 12:50 PM   #4 (permalink)
Sammy Sandbag's Avatar
Just wait for Rancho's adjustable coil overs. They should allow adjustment up to 3" in the front. This however will increase your CV angles for you 4wd owners. Rancho said they should be available later this year.
-Counsel Yourself
Old 06-14-2004, 09:41 PM   #5 (permalink)
loutitan's Avatar
I think we have to be patience to have a great leveling kit since Titan has not been long enough.
Last time i talked to rancho they will release adjustable coil overs.
So just wait.
loutitan is offline   Reply With Quote
Old 06-15-2004, 12:10 AM   #6 (permalink)
Arrrrghhh... Wait you say! I nearly slipped off my seat under hard braking today. (slight exageration) I cannot wait!
I figure, once the new Rancho adustable coils come out I will pick them up. Obviously, I will have to take out the struts on it now to put the new Rancho's in. What am I going to do with them? Hang them in the garage as an ornament? So what difference does it make if I destroy them with a daystar kit? If I can get 6 months out of them until a real set of struts come out, all the better. If I ruin them before they come out, well, I will deal with some noise.
I will at least pick up the new and improved Daystar kit. You know, the one where the morons said it is fixed because they changed the proportion of the two spacers, but kept the same 2.5 inches of lift. Man it is tough being insane. Some people take it for granted.
Old 06-15-2004, 02:29 AM   #7 (permalink)
loutitan's Avatar
how about this:
http://www.skyjacker.com/products-new-nt25.asp
any thoughts?
Old 06-15-2004, 05:50 AM   #8 (permalink)
I am yet another dying for a cure to the tilting nose..........
That Skyjacker kit looks interesting!!
Tom
2005 Titan KC, Black
SE/ OffRoad/BigTow/Utility Bed packages
Stillen Supercharger
AEM Brute Force Intake
JBA Headers
TrueTrac Differential
Roll-N-Lock Cover
Bushwacker Flares
Carriage Works Grille
Wade Deflectors
ProComp 6" Lift
Perfomance Accessories 3" Body Lift
Kenwood Subwoofer
ProVehiclePhotos.com
nfr5111 is offline   Reply With Quote
Old 06-15-2004, 06:08 AM   #9 (permalink)
geece1's Avatar
While the jacked up look is not pretty, I agree with Zardoz that the truck performs great when you dump a load in the bed (1,800 lb pallet over the rear axel). She was level and road great.
Hopefully something will pop up soon to help.
2004 Red KC 4X4 SE
SE Popular Bench
Big Tow
Utility Bed Extender
Utility Bed Toolbox
shopping for...
Step Rails
geece1 is offline   Reply With Quote
Old 06-15-2004, 09:07 AM   #10 (permalink)
That's your call man, if you can't wait and want to drop $100 + install then probably $1000 on the coil overs, then more power to you. I would like to see the truck leveled out as well, but I'm waiting to see the 4-6" lifts that are coming out later this year.
how about this:
any thoughts?
Same exact thing as the DayStar, CST, and Rough Country coil spacers. They are all going to run the risk of topping out your front struts. The only difference is the Rough Country is .5" shorter. The rubber compounds might vary, but that will only effect the "ride" and I doubt the differences are measurable. I'd say if you are destined to buy one, go with the least expensive.
-Counsel Yourself
Old 06-15-2004, 04:13 PM   #11 (permalink)
BTW, talked with Rough Country today. The RC 2inch and the Daystar 2.5 inch are the exact same kit. RC only called it a 2inch because the net lift was more like 2.25 instead of 2.5. They get the spacers direct from Daystar. Just thought you guys guys might find this interesting. RC also indicated they had no knowledge of different versions of the kit. They are all the same Daystar spacers, no different compounds, no different proportions, etc... Just Daystar.
Old 06-15-2004, 04:16 PM   #12 (permalink)
BTW, just looked at the Skyjacker kit in that link. Daystar. I bet you a million bucks you call them up and ask them where they get their spacers. According to the guys at RC, Daystar is one of the only two companies in the US that makes poly-anything for automotive. What good will the "Skyjacker" shocks do you in the rear? Bahaa, the rear is not sagging!!!
Old 06-15-2004, 05:40 PM   #13 (permalink)
Mike H.'s Avatar
Why doesn't somebody (such as Rancho or Skyjacker) just make a 2.5" longer version of the front shock, and sell a complete spacer kit which includes the longer shocks? It'd still be less than $300 as a leveling kit. Why is it rocket science to make a slightly longer shock?
Then you could throw in 2.5" blocks in the rear if you like the rear higher look (which I do). You could then go 2.5" all the way around including shocks for about $500. I don't want an 8" lift (or the associated cost), but would like to have it a little higher.
EDIT: I just checked the Skyjacker site. They do offer the Hydro, Platnum and Nitro versions of the front shock for a 2.5" lift. So why not just pick them up with the spacer kit?
Mod links (clickable):
Old 06-16-2004, 04:07 AM   #14 (permalink)
hmm, no kidding... Longer struts would fix my problem, I might look into the skyjacker kit front struts...
Old 06-16-2004, 07:30 AM   #15 (permalink)
I talked to Skyjacker and they said that was a misprint. Those are rear shocks, not front struts.
workman1000 is offline   Reply With Quote
