Old 10-15-2004, 10:44 PM   #1 (permalink)
Send a message via AIM to MaxPowers
CST lift gas mileage
Well i finally stopped being lazy and decided to figure out what my MPG is with my 35" tires and lift. It was all pretty much city driving and i drove about 263 miles on a full take and got a little over 10 MPG. Talk about gas guzzler. The gas was 2.33 a gallon which is the cheapest i can find in east county of san diego and it cost about 60 bucks to fill up from being empty. Just some info for you guys curious on the gas mileage.
MaxPowers is offline   Reply With Quote
Old 10-16-2004, 12:45 AM   #2 (permalink)
morpheoussc400's Avatar
Send a message via Yahoo to morpheoussc400
Did you recalibrate your speedo for the difference in the size of the tires? If not you probably went farther than 263 miles. (Rolling circum. of stock off road tire 617 revs per mile, while 35's approx. 576) When you calculate it out... I figure you're getting about 11 mpg, and considering 35's probably have a higher rolling resistance than stock tires, thats actually not too bad.
[FONT=Comic Sans MS]undefined[/FONT][SIZE=5]undefined[/SIZE]undefinedMike L.
morpheoussc400 is offline   Reply With Quote
Old 10-16-2004, 12:36 PM   #3 (permalink)
Yeah i forgot about that since i did not recalibrate it. It doesn't seem that bad but when the gas prices are this high it seems bad.
Old 10-16-2004, 06:49 PM   #4 (permalink)
NorCal 4x4's Avatar
Assuming starting with an Off-Road or Big Tow Pkg. then switching to 305/75R/17 tires, (after lift, and not accounting for any other factors than tire size):
Data
OE Tire Width (mm) --- 285 ------ New Tire Width (mm) --- 305
OE Aspect Ratio --------- 70 ------ New Aspect Ratio --------- 75
OE Rim Diameter (in) --- 17 ------ New Rim Diameter (in) --- 17
Sample Speed ----------- 60 ------ Sample Travel Distance: --- 1
OE Gear Ratio -------- 3.357
RESULTS
OE Tire Diameter (in) ------- 32.7 - New Tire Diameter (in) ------- 35
Tire Dia. Difference (%) ---- 7.04 -- Difference Direction: -- Larger than OE
Original Odometer Reading ---- 1 -- New Odometer Reading: -- 0.934
Original Speed Reading ------- 60 -- New Speed Reading: ------ 56.05
Instrumentation Error (%) -- 7.04 - Error Direction: -------- Less than actual
Effective Gear Ratio ------------------------------------------------ 3.136
Here's the link. Remember to change the OE Gear ratio, if you don't have Off-Road or Big Tow.
Tire Size Calculator
Old 10-16-2004, 09:31 PM   #5 (permalink)
HVACman's Avatar
Yea - I got about 12.5 hwy after lift with 35's. Got 15.5 before lift with stock tires.
Titan CC LE 4x4 Radiant Silver * Born 4/16/04 * Big Tow / Offroad Package * Kenwood DVD/NAV ent. system * Infinity 6000cs Component Speakers * Infinity 7540A Power Amp * SPL Sub Power Amp * 2 10" PowerBass Subs * Tsunami 1-Farad Capacitor * JBA Ceramic Coated Headers * Flowmaster 40 Series Catback System * Sirius Satelite Radio * K&N 77 Series FIPK Intake System * Airaid Throttle Body Spacer * Really Loud Air Horns * Weld Racing Cheyenne Rims * Carbon fiber dash kit * Black billet grille * Truxedo Tonneau Cover * CST 7" Lift * ProComp XTerrain 35/12.5/17 Tires * Procomp Traction Bars * Stainless Steel Brake Lines
Wherever you go, there you are
HVACman is offline   Reply With Quote
Old 10-16-2004, 09:45 PM   #6 (permalink)
NorCal 4x4's Avatar
Hey HVAC, I missed your "_____", (deleted for stealth mode), Avatar, that was really one of the best I've ever seen, but I don't recall the username?
o.k. found it. Sorry if you're underground or something. Actually I was thinking of changing mine to something else, too, (something more Titan-like. Mine sounds lame). I guess if JetForeman can do it, anyone can.
Old 10-17-2004, 11:28 AM   #7 (permalink)
HVACman's Avatar
swarren1 - Sorry, i guess i haven't had enough coffee today; I'm not following what you're talking about...
Old 10-17-2004, 11:38 AM   #8 (permalink)
NorCal 4x4's Avatar
I was just commenting that I liked your old Avatar better, (not that I don't like your new one or anything), and then with your new username, at first I couldn't place you, (associate you with your previous posts).
Old 10-17-2004, 11:51 AM   #9 (permalink)
HVACman's Avatar
Ah! I changed my avatar for Halloween; I get a little tired of the same thing all the time anyway. As far as my user name goes, my son set up my account not realizing that he was using my name for the user name. It hasn't caused any problems but, when I came accross a thread about how to change I did it. Im not underground for any reason.
