Got a question for anyone.
Since the Armarda has independent rear suspension, do you think it would be possibe to convert the Titan to independent suspension, and what would be the positive and negitive effects?
TITAN-IUM
04 Titan 4x4 SE / Smoke
Born on 12/09/2003
(Took Delivery): 1/15/2004
Popular Bench / Titanium
Mods:
2.5 Inch Front Leving Kit
Banks Monster Exhaust
TREX Upper and Lower Billet Grille Inserts
Intake to come - Currently have Fram AirHog installed
04 Subaru Forester 2.5 XT / Silver
Mods:
Perrin Short Ram Intake
ADR Wheels covered in TOYO rubber
I didn't realise the Armada is independent rear-thought it was solid axle like the Titan.Live and learn.
It won't be possible to easily make the switch for a reasonable amount of money(say under $3000),unless you are very handy fabricating metal etc,and stealing parts!.It is always possible to switch stuff ,it just is absurdly expensive-say $10,000-$15000 to add independent rear to the Titan.
Factory built independent would be better than a solid rear axle in every respect-ride comfort,handling,cornering,ground clearance etc.Only possible downside is that it isn't as rugged if you plan to ram rocks with it like the slow speed offroaders do(fastest Baja vehicles are independent all around,but they try to avoid rocks).There might be some towing benefits to the solid also-could be ruggedness once again.So my vote is great idea,but way too expensive.Luck,Charlie
I definitely agree that it would be an expensive swap, but it sure would be cool lookin to have a BAJA style Titan. I wonder if any of the mounting holes are already on the frame?
TITAN-IUM
Born on 12/09/2003
Mods:
Mods:
I've converted several Mustang Cobras(which have IRS) to stick axels. Stick is actually preferred in racing right now do to it beefyness and simplicity.
Converting a Titan can be done and most likely not that difficult. It would be hard to believe the the frame rails dont have the mounting points already there. It should be a bolt on affair. Similar to the Mustang. I would find it hard to believe that nissan wouldn't do it for the same platform. I would bet that most of the similar parts from an infinity SUV would also bolt into our trucks. The ride and handling would be better but I'd be willing to bet your not going to be towing 9000 lbs with that thing for very long.
Cost is mostly an issue of what your skill level is. I'm sure you could find a totalled Aramada in a junkyard and pull (or have pulled) the rear & Bolt it right up to the Titan's frame. For not much money. But if your unskilled and have to have a shop do it then yeah I can see it getting costly.
I find it hard to believe people are spending $2500+ for lifts.
Why would having independent rear suspension intefere with towing?
Armada has a 9100 lb Tow rating...
__________________ JBA Longtube Headers
Cajun Catted B-pipes
JBA Catback exhaust with Vibrant UltraQuiet Resonator
Tuning by UpRev (Seymore4) IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
It doesn't interfere. But I wouldn't want to tow anything heavy with an IRS. It will tow it don't get me wrong. Otherwise it wouldn't be rated to tow! I just think the longevity isn't as good as a stick axle. IRS isn't as strong.
Due to differences in vehicle lengths, you would obviously need a CUSTOM drive shaft.
I would go for the QX56 rear end, it has air ride/auto leveling, etc. although that can be added aftermarket, just nice and clean for everything to be OEM or Nissan parts.
I like the fact that when the rear end articulates over obstacles, the IRS system would keep the entire width of the tires on the ground, rather than riding on an edge like solid axle.
ALSO the obvious ground-clearance advantage would be nice.
Just watching BAJA and SCORE races on TV makes IRS seem so desirable and advantageous.
I agree that it would cost "un chingo dinero" to do it right though. Maybe wait till the vehicle is out of warranty....?
KC XE Smoke
The Following User Says Thank You to pciley For This Useful Post:
