The guy in Canton must have been on crack when he tightened that one. The other one came right off.
Make me laugh!
The upper, and lower bushing bolts should be loosened to help the install, and re-tightened to "capture" the bushing at the new ride height after it's back on the ground. Be careful not to mess up the alignment cams, just allow the bushings to adjust themeslves.
Well, actually the frt end should be aligned ASAP to prevent any premature tire wear.
I'm a off-road guy, and will be getting the 2wd kit real soon!
