User Name
Password
Wider tires w/ PrerunnerGreg's kit! - being discussed at Nissan Titan Forums in the Titan Suspension section.
Old 10-11-2004, 07:13 PM   #1
PaCoAsTiTaN
Talking Wider tires w/ PrerunnerGreg's kit!
Installed my kit from PrerunnerGreg three weeks ago. Drove on it for 550+ miles at 70-80mph. Then upgraded my wheels & tires to 325-60-18 Nittos on 18X9s. Drove it another 550+ miles and remembered why I got the leveling kit.
I got this kit because I wanted bigger tires. My 4X4 SE OFF ROAD already came pretty level but couldn't fit the 33 inch Terra Grapplers on the front.
The combination of PrerunnerGreg's kit, 325/60/18 Nittos, and Bushwacker fender flares has dramatically improved my ride & appearance. Will post pics soon.
PaCoAsTiTaN is offline   Reply With Quote
Old 10-11-2004, 10:15 PM   #2
IQ9
Can't wait for the pics. Do you have any before and after shots?
Crew Cab,Pearl White,LE,Venture Clear Bra, Debadged, PML Dif Cover, 285/60/18 Nitto Terra Grapplers & Stillen BBK
IQ9 is offline   Reply With Quote
Old 10-12-2004, 06:43 AM   #3
KATM
Yes, Please posy some pics so we can all see! Do you have any rubbing when you hit a bump with the wheels turned?
KATM is offline   Reply With Quote
Old 10-12-2004, 08:57 AM   #4
imjustdamngood
imjustdamngood's Avatar
Send a message via AIM to imjustdamngood
Do you know if Prerunnergreg's leveler kit has any side effects like the daystar leveler kit has? like increased stress on anything? i just dont want my truck to get messed up. thanx
imjustdamngood is offline   Reply With Quote
Old 10-13-2004, 01:23 AM   #5
PaCoAsTiTaN
PrerunnerGreg Kit / Bushwackers / 33" Nitto Terra Grapplers
I've heard only good things about this kit and now I see why. Thanks to the advice of 1BadTitan and others, the choice was easy to go with this kit over the Daystar Kit.
The 325/60/18s only rub the inner backside plastic when fully turned in. Never have any problems during normal driving. A little rubbing in slow tight turns & reverses. Bushwackers had to be trimmed on inner side. Front factory mudflaps would need to come off.
Just installed the new Aries Nerf Bars today!! Will post an updated pic soon.
BEFORE>>
STOCK > Front end appears even lower when parked on a slight downward slope. First mod was the Flowmaster Dual set up.
AFTER>>
Added PrerunnerGreg Kit / Bushwackers / 33" Nitto Terra Grapplers
4X4 King Cab SE/ OFF ROAD / BIG TOW / Flowmaster 70, X pipe, dual tip "Sammy Style" / AIR BOX MOD w/ K&N Filter / Mobil 1 5w-30 / United Prerunner Leveling Kit / 325/60/18 Nitto Terra Grapplers / 18X9 Pro Comp Extreme Alloys / Westin Bull Bar w/ PIAA 525s / PIAA WHITE Headlight Bulbs / Carriage Works Billet Grille / OEM Hood Protector / Aries Nerf Bar / Bushwacker Fender Flares / Truxedo Cover / Utilitrack w/ Extender & Divider / Razo Shift Knob / Razo Pedals / Nismo Oil Cap / Nismo Valve Stem Caps / Black Corner Lens "1BadTitan Style" / Red Reverse Tail Light / Low Profile Antenna
Old 10-13-2004, 04:14 AM   #6
tmoran
which size of spacer did you use?
tmoran is offline   Reply With Quote
Old 10-13-2004, 05:09 AM   #7
PrerunnerGreg
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Pacostitan has the "off-road" package spacers. They are just under 1.25" thick. Or are you asking about the overall lift increase? which is around 2".
Old 10-13-2004, 06:00 AM   #8
Mike H.
Mike H.'s Avatar
My OR spacers added exactly 2.5" to my OR Titan.
Mod links (clickable):
Old 10-14-2004, 12:37 PM   #9
04titan18
where can i find this prerunnergreg leveling kit?
04titan18 is offline   Reply With Quote
Old 10-14-2004, 08:15 PM   #10
TITAN4x4
Go to prerunners.com and click on the link.
TITAN4x4 is offline   Reply With Quote
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
