Originally Posted by neworleansmike
says it helps eliminate vibration between 25 and 60 mph all my vibration / noise comes only upon accelaration from a stop and stops after the truck gets up to 5 to 10 mph. thats why i was trying to see if it was axel wrap or maybe the tires are just trying to spin.I'm going to call procomp in the morning if it is only 40.00 it be worth a shot.
Thats not axle wrap. It is driveline shudder from incorrect angle of the driveshaft. Carrier bearing shim kit, reindexing the X-Fer case, or a CV rear driveshaft can fix that problem.
Axle wrap feels like the rear end of your truck is standing up when accelerating hard...then it will go back down....it has nothing to do with vibration...that is coming from your driveline.
I don't know what your carrier bearings look like, but on SD's its a simple shim kit with shims that are different thicknesses that you stack to get the correct angle.
Can someone post a pic of the Nissan Carrier bearing and this kit you have?
JAKD 2007 Dark Stone Harley Davidson Edition Super Duty Custom Built By Truck Toyz Performance
Special Thanks to: Trucktoyzperformance, Rize Industries, Autometer, MBRP, Line-X of Friendswood TX, Accufab Racing, Painless Performance, Retrax, and DC Customs
