Old 05-03-2005, 07:15 PM   #31 (permalink)
EPTITAN's Avatar
Location: some where between bum f&*$ Egypt and you got a pretty mouth
Originally Posted by byrdman
I'm have a similar problem with my cst kit. when i get on it i hear a popping or maybe a slipping? sound but only when its hammered down normal driving is fine. I dont think its axle wrap b/c i had a tacoma with 9 inches of lift and one point in time had a 5 inch block and had plenty of axle wrap. Any thoughts helpful.
Sounds like you have the same problems as us. Looks like neworleansmike will have his on soon, I guess its wait and see at this point.
EPTITAN is offline   Reply With Quote
Old 05-03-2005, 07:35 PM   #32 (permalink)
EPTITAN's Avatar
Originally Posted by Bear Hunter
Thats not axle wrap. It is driveline shudder from incorrect angle of the driveshaft. Carrier bearing shim kit, reindexing the X-Fer case, or a CV rear driveshaft can fix that problem.
Axle wrap feels like the rear end of your truck is standing up when accelerating hard...then it will go back down....it has nothing to do with vibration...that is coming from your driveline.
I don't know what your carrier bearings look like, but on SD's its a simple shim kit with shims that are different thicknesses that you stack to get the correct angle.
Can someone post a pic of the Nissan Carrier bearing and this kit you have?
here are some sorry if you can't see to well, crawling under there in the dark and taking them didn't turn out so well.
sounds-like-rear-tires-trying-break-loose-after-lifting-rear-p1000348.jpg  sounds-like-rear-tires-trying-break-loose-after-lifting-rear-p1000352.jpg  sounds-like-rear-tires-trying-break-loose-after-lifting-rear-p1000357.jpg  sounds-like-rear-tires-trying-break-loose-after-lifting-rear-p1000356.jpg  sounds-like-rear-tires-trying-break-loose-after-lifting-rear-p1000353.jpg
Old 05-03-2005, 08:52 PM   #33 (permalink)
Bear Hunter's Avatar
I see what you are talking about now. I was hoping it would be easier than that. Yeah...your going to need to grind that sucker off. Let us know how it turns out
byrdman,
What do you mean by popping and slipping? Take off shudder/vibration? Are your U-bolts / eye bolts / shackles torqued to spec?
JAKD 2007 Dark Stone Harley Davidson Edition Super Duty Custom Built By Truck Toyz Performance
Special Thanks to: Trucktoyzperformance, Rize Industries, Autometer, MBRP, Line-X of Friendswood TX, Accufab Racing, Painless Performance, Retrax, and DC Customs
Bear Hunter is offline   Reply With Quote
Old 05-05-2005, 04:23 PM   #34 (permalink)
Send a message via AIM to MaxPowers
So has anyone installed the that procomp carrier bearing drop kit yet?
MaxPowers is offline   Reply With Quote
Old 05-06-2005, 10:36 AM   #35 (permalink)
I Am Either Sat Or Sun Will Post How It Worked
neworleansmike is offline   Reply With Quote
Old 05-06-2005, 12:05 PM   #36 (permalink)
EPTITAN's Avatar
Won't be able to get mine done until next weekend.
Old 05-09-2005, 09:35 AM   #37 (permalink)
Any news neworleansmike?
Old 05-09-2005, 11:14 AM   #38 (permalink)
HAD TO ORDER THE BEARING BRAKET I TRIMMED A LITTLE TO MUCH OFF AND WACKED OFF ONE OF THE TABS IN THE PROCESS. I NURSED IT HOME WITH ONLY ONE BOLT THROUGH THE BRACKET, AND I DIDN'T NOTICE THE NOISE. BUT THEN AGAIN i DIDN'T HAVE A CHANCE TO FLOOR IT WITH ONLY ONE BOLT THROUGH THE CARRIER BEARING ITSELF. MY BRACKET WILL BE IN TOMMOROW AND i AM GOING TO REASSEMBLE AND WILL LET YALL KNOW
Old 05-10-2005, 04:03 PM   #39 (permalink)
Just finished reinstalling the bearing bracket....the kit eliminated all the racket in the rear end !!!!!!!!!!!!!!!!!!!!!!!!!! Floored the truck on a turn and spun the tires instead of hearing all that racket....awesome $35.00 part solved the problem
Old 05-10-2005, 05:23 PM   #40 (permalink)
EPTITAN's Avatar
Glad to hear it, I hope it takes care of mine also.
Old 05-10-2005, 09:09 PM   #41 (permalink)
Sweet!!! I am definately going to get this. I'm probably gonna have to get it installed though. Hey eptitan, are you having a shop install it? and if so what are they charging you?
Old 05-11-2005, 10:01 AM   #42 (permalink)
EPTITAN's Avatar
The place that installed my lift said that it would be between $35 and $65 to install.
Old 05-11-2005, 11:37 AM   #43 (permalink)
Eptitan...definetly money well spent. Like everything else it wasn't as simple as the instruction show. First of all the aluminum slugs don't fit the bracket like they are shown. We had to grind a bit off just to get them to fit. The templates don't line up worth a ****, and of course trying to cut out the center support frame from the truck with the bearing still in the way can amount to cutting the tab off the bearing bracket. But again what a wonderful kit. I can spin the rear tires upon take off with no noise from the rear end..
Old 05-12-2005, 05:20 AM   #44 (permalink)
EPTITAN's Avatar
Can't the bearing bracket be taken off the brace bafore you cut it off? It is only held on by 2 nuts correct?
Old 05-12-2005, 09:32 AM   #45 (permalink)
yes you are correct,it can be taken off first and I know that the hard way now....
