Originally Posted by MaxPowers
I'm gonna be installing this the following weekend. I see there is cutting, any advice on what kind of tools to use?
I just bought a cheap grinder and used the little cutting wheels. Makes sure you have a couple extra cutting wheels just in case. When you disconnect the bracket it is easiest to work on if you tie the drive shaft up and as far out of the way as possible. Try and keep the drive shaft lined up exactly as stock though when installing ( the template holes are off a little).Take your time on making sure the holes are drilled correctly. Another problem is when you put the aluminum spacers in the bracket and try to lower in place they fall out before you can run the bolts through, I super glued them in place after several attempts.lol. It worked though. Hope this helps.
