Old 05-10-2005, 08:37 PM   #1 (permalink)
Racerunners
I recently saw an ad in an offroad mag, the racerunner coilovers are out. Sweet deal do you guys think that they will work with the cst 8" for the 2wd. I think that they are supposed to lift the truck up to 3 1/2" that is all of the way preloaded most likely, that may not be the best ride. So what do you guys think about a prg kit around 2" and the coilovers turned to 2" to make the 4" that the factory coilover gets with the cst spacers installed, that way it would be possible to get the best ride. confussed? you should be.
mobspade is offline   Reply With Quote
Old 05-11-2005, 08:08 AM   #2 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Wont work unless you modify the upper a-arm or change mounting points. You can get 3.5" lift easily, but the ride quality will suffer.
PrerunnerGreg is online now   Reply With Quote
Old 05-11-2005, 08:48 PM   #3 (permalink)
so your kit + racerunners w/ 2" lift and the rest of the cst kit will not work?
Old 05-11-2005, 09:10 PM   #4 (permalink)
Are you talking about the 8" cst kit?
Old 05-11-2005, 09:15 PM   #5 (permalink)
yeah the 8" use yours, with the racerunners instead of the stock coilovers and the big 4" cst spacer for the 8"
Old 05-11-2005, 09:51 PM   #6 (permalink)
Just use a SAW 8 inch coil-over with custom mounts or something specific. Dont combine kits, they wont work together.
Old 05-11-2005, 10:12 PM   #7 (permalink)
See post above, the shock with the longer ends are built just for your application.
Old 05-12-2005, 01:10 PM   #8 (permalink)
DaFridge's Avatar
can you get the custom mounts from SAW?
we're not here to start no trouble, we're just here to do the SuperBowl Shuffle!!"-1985 SBXX CHICAGO BEARS!!!!
2004 DEEPWATER
AEM BRUTE FORCE DRYFLOW
CUSTOM FLOWMASTER 40 DUAL THUNDER
T-MAXX OUTBACK WINCH
procomp stage2
PRG traction bars and endlinks
American racing mojave teflon 17s
35" XTERRAINS....these tires ROCK
safari softopper
Kc LIGHTS
www.off-road.com/nissan
DaFridge is offline   Reply With Quote
