Old 05-13-2005, 08:15 AM   #1 (permalink)
Tried some 20s, need PRG asap...
Hi there, yesterday I went to my local Toyo dealer to try 20" rims and 305x55 Toyo Open Country AT, the tire barely rubbed(scratched would be too much, touched only) the plastic just above the mud guard, one of the workers there said that it wouldnt be a problem and that I only needed to put a cinch in that plastic liner to hold it backwards so that the tire would hit it.
Is that a doable thing?
Suspension Mods:
BFG MT/KO 35"x12.5"r17
Audio Mods:
Cooming soon:
HIDs and Yellow Fogs...
Old 05-13-2005, 08:32 AM   #2 (permalink)
VShortt's Avatar
Just about everyone here that has done 20's and new tires has had some sort of rubbing issues. All of which were corrected. The plastic lining on the inside can be cut or even re-shaped with heat. Several on here have taken just such an approach and had good results.
New List of Mods Coming soon
Old 05-13-2005, 11:30 AM   #3 (permalink)
Take off the plastic, behind it you will see a pinch weld that keeps the plastic from pushhing in. Grind this pinch weld down and you will be able to pick up a little more clearance. I just pop rivited the plastic trim back to keep it fitting snug inside the fender well
neworleansmike is offline   Reply With Quote
Old 05-13-2005, 11:38 AM   #4 (permalink)
QWIKWHIP's Avatar
Yeah, what Mike said, but I used a heat gun to "reform" the fender liner back rather than the poprivets.
Old 05-17-2005, 01:20 AM   #5 (permalink)
dragonhead08's Avatar
any chance you guys have pics of the "pinch weld" and the reshaping that had to be done?
KMC ROCKSTARS 18X9 0 OFFSET 5.5" OF BACKSPACING
TIRES NITTO TERRA GRAPPLER 325/60/18
2" LEVELING KIT WITH PINCHWELD MOD.
dragonhead08 is offline   Reply With Quote
