Old 05-24-2005, 04:48 PM   #1 (permalink)
SoulFish's Avatar
Question 6" Lift - What happens to Towing??
How does the 6" suspension lift effect towing?
I tow a 24' 7,000lb boat. Right now it tows fine the rear sags alittle when the tong hitch is on, but I cant complain. Anyone tow heavy loads with this lift? If so how far do you tow, how long are the towing periods?
- thx
Steve Piazza
04 Titan, Crew, 4x4 SE, Tow, Offroad pack, Locking Rear, RF Sound, Utility bed pack, Pop pack
Mods: Tint, Westin Bull Bar, HID Bulbs
SoulFish is offline   Reply With Quote
Old 06-01-2005, 12:01 PM   #2 (permalink)
DStewart's Avatar
From what I understand if you use the blocks to lift the rear you can still have airbags in the rear. That would help with the sagging.
SOLD:2004 Nissan Titan 4x4-Smoke, Big tow, SE bed package, Popular package w/ captains chairs.Mods: updated aluminum rear diff cover, K&N drop-in filter, PRG lift, Firestone air bag kit, 17x9 Eagle Alloy 101's, 295/70R17 Nitto Terra Grappler, polished Billet grille-upper 3 piece and lower.
2005-FS2600 Weekend Warrior toy hauler
05 Honda CBR 600RR Black/Gunmetal w/Tribal Flames
DStewart is offline   Reply With Quote
Old 06-01-2005, 02:15 PM   #3 (permalink)
ptgarcia's Avatar
If you run 35" tires (I'm sure you are) you will lose pulling power. The 35's are taller and heavier with a larger contact patch. All this adds up to more rolling resistance. The bigger diameter also affects the final drive ratio, giving the feeling you are running taller gears in the differential. So you will feel a difference.
As far as capacities go, nothing should change, however you will be heavier, thus lowering you cargo carrying capacity. Also, be careful if you use lift blocks in the rear. Most are cast aluminum and may not react well to a heavy load, but Im guessing your boat probably only has a 700 lb or so tongue weight.
To help with the sagging rear look into Air Lift airbags or Timbren Aeon convoluted rubber springs. I have the Timbrens on my crew cab and they made a difference when pulling my 8000 lb trailer. They also helped smooth the ride over bumpy roads.
Good luck!
Pauly
Old 06-08-2005, 07:08 PM   #4 (permalink)
I have found with 35's the shift points are different it seems to hang up in the lower gear and i have release off the gas to get it to shift ro lower gear
also you will not register about 10% for example for every 10 miles shown on the odometer it is actually 11 miles and you are going 3 miles and hour faster than the speedo
I was checking it with my GPS
Calhoun687 is offline   Reply With Quote
