I'm looking at putting the PRG leveling kit on my 05 4x4 titan w/o the off road package. I want to put the 1/5" block for the rear but I noticed you "might" need to replace the shocks. What do they mean when they say "might"? Is it possible to do it without replacing the shocks? Also, does anybody have any pics of a titan with both the front and rear kits installed? Thanks!
Here is a pic of Havock's truck with a 2.5" front / 1.5" rear PRG lift.
Send a PM to PrerunnerGreg (PRG) and he can answer any questions you have.
Also if you do a search, there is a ton of info on PRG.
Hope this helps....
__________________ 2005 Silver Titan LE CC 4x4
Off Road, Big Tow, Sunroof,
NAV, DVD, Side Air Bags,
Floor Mats, Splash Guards,
Sliding Bed Extender
Mods:
Rancho 4" Lift w/ Fox Coil-overs,
Bilsteins, & Deavers from PRG,
Total Chaos Upper Control Arms &
Stainless Sway Bar End Links - PRG
Window Tint, Banks Monster Exhaust
Black Bib on tailgate painted Silver
AVElectronic NAV Video Switch
MB OffRoad "Gunner 6" - 17 x 8
315/70R17 Yoko Geolander A/T-S
Dunder Dan Chrome Grill
Infiniti Center Console Lid
Active Tuning Grounding Kit
UnderCover Tonneau Cover
I have the 2.5" front and 1.5" rear kits on my Titan. I have the 2WD w/ OR, and am still running the stock Ranchos in the rear. I only have a problem with them when I go over a speed bump to fast and the rear drops, or if I try to get too much axle articulation. Those will cause the shock to bottom out and I hear the clunking sound. Other than that, normal on road driving doesn't cause a problem with my current setup.
That being said, I received my new PRG Bilstein rear shocks yesterday and will be installing them when I get my new leaf packs next weekend. I wanted/needed the new Bilsteins for a couple reasons. First, they give the longer travel that I can use now, plus the leaf packs will give me an extra 1.25" of lift which will put me well past what my Ranchos can handle. Second, the Bilsteins are a much better quality shock and will give me much better on and off road performance/ride quality.
As TCW mentioned, contact PRG with your questions/concerns and he will help you get the setup that you need for your truck!
i asked greg something similar and this is what he said
Jeff, I ran 1.5" blocks for a long time and had no issue with axle wrap, it was no worse than stock and that wasn't bad at all. Any leaf spring truck will have a little, that is part of the design. Your 4x will certainly have less than my 2wd becauseof the shpe of the over-load leaf. Run the block, you can always take it right back out if your not happy. As for the rear shock upgrade, you can get by without it on your 4x, but if you notice the shock "topping-out" over speed bumps and such, then you might consider upgrading at that time. No sense spending money if you dont need to.
I justb ordered PRG'S Front coil overs with Bilsteen shock for the front and rear and also the Deaver Springs. Greg says they should ship mid week next week so hopefully i will have them buyt the weekend and install them if so i will take pictures as soon as it is done
I'm gonna hold out for the Donahoes for the front. They should be a great match for the Bilsteins in the back.
Woo Hoo, can't wait. Just put my order info the leveling kit package. 2 inches front and 1 in the rear.
2005 Blizzard CC, 4x4 Off-Road, Pop. Bench, Utility Bed, PRG 4" performance Lift w/ SAW's and TC UCA's on the front,Deavers and Radflo's on the rear, Custom Magnaflow exhaust, Fram Boost CAI, Nissan All-Weather Floor Mats, 315/70/17 BFG AT's on American Racing 17x8 Fuel 8 Teflon's, PIAA 40 series driving lights
I ended up going with the 1.5" rear block and 2.5" front spacers. I can't wait to get them on and I'll be sure to post some pics. Does anybody know how long it takes for shipping? I wanted to get them on before I go on vacation.
