Old 08-09-2005, 11:17 PM   #1 (permalink)
ptgarcia's Avatar
Fox coilovers are now installed...
Went to Greg's tonight and had the factory Rancho's with PRG leveling kit pulled out and the Fox coilovers put in. Picked up another 1/2"-1" in ride height, and the Fox's ride better also. I haven't had a chance to put them to work yet, but once I do I'll let everyone know how they work.
It seems I am the 1st truck to have them without combining them with another lift (like CST, Rancho, etc.), and the 1st 2wd of any configuration (other than Greg himself) to have the coilovers.
Update:
Drove the truck to work today and hit all the familiar dips, bumps, potholes and the like. The Fox's just gobble them up like nothing. The front end is working awesome! It's time to start looking for some larger ones...
fox-coilovers-now-installed-fox-coilovers-1-75-.jpg  fox-coilovers-now-installed-fox-coilovers-2-75-.jpg  fox-coilovers-now-installed-titan-foxes-2-75-.jpg  fox-coilovers-now-installed-titan-foxes-1-75-.jpg
Pauly
Old 08-09-2005, 11:36 PM   #2 (permalink)
overdose's Avatar
c'mon man, you know we need some pics!
01/04 SE KC 4X4 Galaxy Black Line-X | Grill |Steprails | Monroe Reflex Shocks | PML DC| AC GK|
overdose is offline   Reply With Quote
Old 08-10-2005, 12:29 AM   #3 (permalink)
Austin's Avatar
So, you got the regular height coilovers, not the 6" extended ones?
MY04 SE King Cab 4X4 SOLD!
Old 08-10-2005, 01:31 AM   #4 (permalink)
NorCal 4x4's Avatar
That's surprising since the un-lifted versions are only available on the 2wd. [The lifted version is available for both 2wd and 4x4].
But a lot of people want lifted if they are going to spend the bucks. Lifted does make sense for trails and hill climbing, because of the better approach and departure angles. The actual ground clearance to lowest point is tire-based so a 35" tire is only an inch more than a 33" tire.
For general purpose, and fairly decent dirt road, the Fox coil overs sound trick. For us un-lifted 4x4s, we will have to wait for the Donahoe coil overs, or maybe the Sway-a-way/Racerunners.
Old 08-10-2005, 07:42 AM   #5 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Pt actually bought my old set of foxes, for all of you waiting they are still on backorder (less than a week as of yesterday, i hate waiting). But good news for the 4x guys, i just got a new lower spring retainer that will allow the foxes to be used on a stock height - 3" raised 4x, woo hoo.
Old 08-10-2005, 08:06 AM   #6 (permalink)
IMADOGMAN's Avatar
Greg, I assume that this is still adjustable from ?" to 3" of lift on the 4x
Is that correct?
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 08-10-2005, 08:23 AM   #7 (permalink)
rod_b's Avatar
...But good news for the 4x guys, i just got a new lower spring retainer that will allow the foxes to be used on a stock height - 3" raised 4x, woo hoo.
Ooohhh yeah! What's the availability?
8.04 K11 CC LE 4X OR BT PRG'd
rod_b is offline   Reply With Quote
Old 08-10-2005, 08:51 AM   #8 (permalink)
JTD
Pauly, how are you liking the Bilsteins with the big tow and FOX combo?
Also Greg any progress on the upper A-arm replacement?
JTD is offline   Reply With Quote
Old 08-10-2005, 08:59 AM   #9 (permalink)
ptgarcia's Avatar
I'm trying. Someone borrowed the camera and hasn't returned it yet. I'll try to take some at work today with the company camera and get them posted.
That's correct.
I've had enough of the "tall" 6"+ suspension systems, especially on a 2wd. I'd much rather stay around 3-1/2" with a suspension that looks better than stock, works better than stock, clears 35's (although I'll stick with 33's until someone makes a lower set of gears), and is durable enough to handle virtually anything I through at it. I love the look of the 6"-8" lifts (like yours Austin...thats a nice looking truck!) but they don't do what I need them to do.
Pauly
Old 08-10-2005, 09:26 AM   #10 (permalink)
ptgarcia's Avatar
So far I like them alot. This truck rides and handles really well on the road. I haven't towed with the Foxes yet, but the Bilsteins have been awesome. They are much firmer than the stockers, which helps when towing, but they still ride better when unloaded.
My problem now (not really a problem, just another bump on the road to a perfect suspension) is the rear springs. I need to get the Deavers on with a set of airbags so I have that smooth, almost car-like ride when unloaded and while tearing up the fire roads then can pump-up the bags to help support and control the load of my trailer. Greg has a set of the Firestone bags in his garage that he's going to put on his 4x2. If all goes well I guess I'll have come up with another $500 and just finish the rear.
Pauly
Old 08-10-2005, 09:36 AM   #11 (permalink)
Banned
95wolverine's Avatar
Ah ha... apparently I was a day late in asking Greg about buying his old Fox Coilovers... always a day late and a dollar short.
PT....still in a holding pattern on front struts... told the dealer what happened and how I did it.. he was pretty sure that the strut should have handled the twisting.. looking into what he can do for me.
If I can get a new replacement @ little to no cost.. I'll look into it. I hate the idea of spending money on replacement struts and getting the "Same old OEM" ride. If I'm gonna spend some money, AFTERMARKET is the way to go.
To get back on topic.. We need PHOTOS!...
Hows it go.. TTIWWP ?
95wolverine is offline   Reply With Quote
Old 08-10-2005, 09:48 AM   #12 (permalink)
ptgarcia's Avatar
No problem. I'll hang on to them a little while longer before listing them in the buy/sell forum.
I'm in total agreement with you there. I hate replacing "adequate" stuff with an "adequate" replacement. I always try to go "better".
Soon, I promise...
Pauly
Old 08-10-2005, 05:01 PM   #13 (permalink)
Banned
tortuga's Avatar
I'm in total agreement with you there. I hate replacing "adequate" stuff with an "adequate" replacement. I always try to go "better"....
better is the only way to go!!! hey pauly, you've got to be lovin' those fox's huh? i drove the mighty PRG titan and as i've said in a another post, wet myself while experiencing the superb suspension characteristics of the coilovers/upperarms/PRG deaver springpack combo. omg, is it day and night versus the oem stock setup. can't wait for the upgrades myself!!! as greg stated, "i hate waiting!!!!!!"
good to see your titan getting outfitted with the best stuff!! take care Pauly!!
tortuga is offline   Reply With Quote
Old 08-10-2005, 05:26 PM   #14 (permalink)
anybody looking for a bulletproof lift? 14 inch with fox coilovers, fox res. powdercoated candy blue 20 inch rims and 37 inch toyo open countrys?
liftedtitan is offline   Reply With Quote
Old 08-10-2005, 05:27 PM   #15 (permalink)
Banned
tortuga's Avatar
bulletproof?
