Old 09-18-2005, 04:38 AM   #1 (permalink)
Titanian's Avatar
PRG coilovers and CST 8" kit ??'s
Do swapping to the PRG coilovers from the stock setup for the CST 8" 2wd Titan add any additional lift?Also,whats the biggest tire you can get on a 2wd with an 8"CST lift and a 3" body?
Thanks,
Reagan
Titanian is offline   Reply With Quote
Old 09-19-2005, 09:38 PM   #2 (permalink)
FdngFrnzy's Avatar
I have a PC 6" lift w/ the 3" Body Lift and I am riding on 37x13.50x20 on 20x10 rims. I had to do some minor trimming to prevent rubbing on full turn or going up or down to fast. I have recently added the Fox coilvers from PRG and WOW what a difference! I had the PC coilovers and they were absolute junk, I put the Foxes on and it rides like a DREAM...I have pics in the photo gallery...
Hope this helps.
Ray
2004 Titan SE King Cab White 2wd
6" ProComp Suspension Lift w/ PRG's Fox Coilovers, MX6 rear shocks & Traction bars
3" PA Body Lift & PRG's Deaver Rear Leaf Spring Pack
37x13.50x20 Nitto Mud Grapplers 20x10 Helo Maxx6 chrome rims
Custom grill inserts by DUNDER23
OEM Bug Deflector & Class III trailer hitch
Hatchie Bottom Custom Fit CAMO seat covers-FRT/R
Retrax
Coming soon...
Custom dual exhaust w/ side exits, CAI, ???
It's a CANES thing...You wouldn't understand!
PICS in the gallery!
FdngFrnzy is offline   Reply With Quote
Old 09-19-2005, 11:23 PM   #3 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Reagan, be sure to check with the shop that does your work to make sure that they use the right coil on your set-up. the CST kits usally need a slightlystiffer coil to maintain full height (or get a bit more).
Old 09-20-2005, 11:03 AM   #4 (permalink)
Titanian's Avatar
thanks guys,i'll check that out.
