I know I can run a 33x12.50R20 but can I get a 35x12.50R20 in there?
Any thoughts before I buy this set up? Any pictures out there with other options too? I definitely not going with a 6" lift but I do want more then just a leveling kit. Does any one have this set up their truck now and do you have pics?
i dont think you can fit 35's on less than a 6" lift i just had one installed and im still rubbing on turns so a 35 with that may rub but someone probs knows more than me
If it were me, and you're dead set on 35s, then just pony up and get a 4" kit which will be more like 5" total height gain. If you get a 4" you can stick to your post saying you definently aren't getting a 6", while still getting warm fuzzy lift feelings.
If that doesn't fit your fancy, 35's ain't happening. And you'll just have to come to means with that.
I know my set up is about all you can do and not mess everything up because I listened, but then you look at it,and it makes people go chit, maybe it wont be the best idea on 3" of lift. You will make 20 point u turns
Like Pa said, if you're dead set on 35's, but also don't want to do 6" lift this is probably your best bet. You'll be paying for 6" but get 4 and probably will have to trim to fit a 12.5" wide tire, but you can squeeze 35's onto it.
A 4" kit will likely be more like 5. And he wouldn't have to trim with stock offset then. 12.5s would be able to clear the frame and not rub. No issue at all.
He just needs any drop bracket lift to effectively clear 35's without have a rub on the frame.
Ok thanks for the replies. So I think I am going to do 3" up front and 2" in the back since I do want some rake. Staying on 33" but should I do it with the same kit from prg that I was planning to buy since the shocks are adjustable?
I actually just completed that exact same lIft on my truck. I did not buy all the components in a kit but pieced mine together over a months time or so. I ended up with the 5100 mid perch + 1.5" billet spacer and 5125s with tapered 2" billet rear block. I got to say that I am very pleased with the ride and the lift. I could have done a bracket lift but my front struts were worn bad giving me a spongy ride and I have a 9 month old baby I needed to get in/out of the truck often.
