The MAN earned his name. PrerunnerGreg is the MAN. He just helped me to install Fox coilover and deaver leaves upgrade on my already "Procomp 6" stage 1 lifted" Titan.
Greg knew exactly on the installation of the kit. There is no "if" or "let see" on him. He can install the kit with his eyes close. I wouldn't let him close his eyes on mine. Greg did a great job. My Titan growed 3 more inches and it looks better than ever. I don't have the shot of the whole truck but here are the before and after of the coil over.
The measurement picture is BEFORE FOX COIL OVER and DEAVER LEAVES UPGRAGE. The measurement after is 60" from the ground.
wow, so your truck is lifted 9" now? Do you plan to run 37" tires? Sounds like a great setup!!
Actually, it is not true 9" lift. The procomp only give you 4". I think procomp said 6" because the lift kit also level your truck too (I think...). With the additional 3", my lift will be 7". It is very comparible to CST 8" lift. I prefer Procomp kit with Fox+Deaver leaves. It is better setup and value for your $. 35" tires look perfect on my lift. I will try to get some pictures today.
Tyltan,
What rear shocks are you running with the deavers? Did you keep the PC MX-6 shocks? Also, does anyone know the difference in length btwn the Fox & ProComp coilovers?
Glxy Blk, XE/CC/4x4
Magnaflow Exaust
AirRaid Intake
DR Coilovers
PC traction bars & lift
BFG 315/70/17 T/A KO's
PC Extream Alloy 1089 stealth black, 17-9 wheels
[/img]
-[/img]
It's better to have it and not need it, Than need it and not have it!"
Tyltan,
I used the shocks came with the Procomp lift. ES9000 series. I don't know the length of Fox and Procomp but for the price difference between PC stage 1 and stage 2, I would go with stage 1+Fox coil over and deaver in the rear. The setup is way better and cheaper.
I already have the ProComp coilovers, I was just wandering if the limiting straps would be the same and what the height difference in the overall lift would be . Thanks.
Mike
Glxy Blk, XE/CC/4x4
Magnaflow Exaust
AirRaid Intake
DR Coilovers
[/img]
-[/img]
Mike
I a sorry that I don't know what you mean by "limiting strap". The measurement from ground to top of my bed before Fox and Deaver was 57 1/4" after fox and deaver was 60 1/4"
