Old 11-20-2005, 03:59 AM   #1 (permalink)
more load
hi all
i am not happy with the Titan load capacity, i want to be able to carry more hevey stuff (double the capacity) what can i do?
i found out that the Titan has only five peices of metal (i think it is called springs) while my other car has like 12 of them
my question is if i increased the number of springs whould i get more load capacity?
i am willing to give away the ride comfert!
are there any other way to achive this?
My titan is for 4x4ing only
thanks
Alkhowaiter is offline   Reply With Quote
Old 11-20-2005, 11:29 AM   #2 (permalink)
Re: more load
I think airbags might help you there... But double the capacity compared to oem is gonna be hard to do.
Suspension Mods:
BFG MT/KO 35"x12.5"r17
Audio Mods:
Cooming soon:
HIDs and Yellow Fogs...
Old 11-20-2005, 12:56 PM   #3 (permalink)
Re: more load
So let me get this straight. You are wanting to do something more along the lines of this?
http://www.nephite.com/images/2001/overloaded_truck.jpg
I am sure if you are willing to do a little fabrication you could rig something up pretty easy. Go to the junk yard and pull some springs off a 1 ton chevy and mount them on the frame of your Titan. Just reinforce the frame where you mount them. IMO I think this could be very dangerous and should not be done. If you only do 4x4 with it why not just go buy a cheap one ton 4x4 and fix it up instead of ruining your 1 or 2 year old Titan?
Old 11-20-2005, 06:57 PM   #4 (permalink)
loufish's Avatar
Re: more load
No matter what you do to the suspension & frame, the rear end is still only rated for 3800 lbs...I would think twice about overloading any rear end by the amount you are talking about.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 11-20-2005, 07:03 PM   #5 (permalink)
Re: more load
Dude you need an F-350 with the highest GVWR they have 4200lbs payload. Why ohh why did you buy a 1/2 ton truck for?
CraigG is offline   Reply With Quote
Old 11-21-2005, 06:52 AM   #6 (permalink)
Mike H.'s Avatar
Re: more load
Or this:
Overloaded Titan
I almost crushed my truck. Did you not know that you needed grossly more load capacity before you bought it? You could add one (or even 2) Add-A-Leaf springs to your rear spring packs, but you will still not get to where you want to be load-wise, and it will ride very rough when unloaded.
Mod links (clickable):
What's the heaviest load you've towed... DaveS Titan Towing & Hauling 31 12-10-2004 12:33 PM
too big of a load? HVACman Titan General Discussion 6 10-08-2004 06:44 AM
How to safely load a vehicle doberboy Off-Topic Discussion 1 08-13-2004 08:15 PM
I weighed this honkin' load! DaveS Titan Pictures & Media Post 4 04-27-2004 02:18 PM
