I spent all day working on this truck and I really liked the way it turned-out. The specs are as follows; Fabtech kit, modified for 2wd so there are no extra brackets and the most clearance possible. Sway-a-way coilovers, 6" body with 8" shaft custom internals and valving, 650 lb/in x 13" spring, custom coil riser to clear the custom/ lenghtened sway bar end links. Total chaos upper a-arms. Custom reservoir mounts. I modifeid a procomp carrier bearing drop down bracket and welded it in place and made the bushing much easier to service if ever needed. It also has the Deaver upgrade pack and a custom tapered 3" rear block. This truck has about 8-9" of lift in front but could easily get another couple inches and ride great. As you can see it was dark when I finished, I will try and get more pics when he gets his new tires and wheels.
I know it has been said before but I just got to say it again: Man, you do great work!
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
