Old 01-31-2006, 10:42 AM   #31 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Re: Titan Bilstein shocks owner comments?
They will fit, but they will probably use a smaller bolt (1/2" instead of the stock 14mm) and they will stack a bunch of washers on the lower mount. I press the old bushings out and replace them with new bushings then machine a cromoly sleve that I press in so its a direct bolt-on. The stock heigthtrucks use a different shock and we use one washer on the upper mount, but the same lower mount.
PrerunnerGreg is online now   Reply With Quote
Old 02-22-2006, 09:19 AM   #32 (permalink)
HyperSportRacing's Avatar
Send a message via AIM to HyperSportRacing Send a message via Yahoo to HyperSportRacing
What is the Bilstein 5100 series part number for a stock 4x4 rear? Anyone? Thanks!
San Diego, Cali.
K4 GSXR 750
2006 Nissan Titan LE CC 4x4 PICS
6" ProComp Kit, DR Coilovers, Total Chaos UCA's, Fox Reservoir Shocks. MotoMetal 954 20x10, Toyo Tires.
Stillen Big Brake kit, AMP Research steps
Need Custom Embroidery or Promotional Items??
HyperSportRacing is offline   Reply With Quote
Old 02-22-2006, 05:02 PM   #33 (permalink)
There isnt one. If you want a generice bilstien, use a "6248" and modify it to fit.
Considering a Titan purchase. Opinions/comments needed mach1 Titan General Discussion 47 12-16-2005 09:29 AM
Nissan's comments about performance of Titan in market GO_VOLS! Titan General Discussion 66 10-17-2005 05:34 PM
PRG Bilstein rear shocks and PRG/Deaver leaf packs installed HavockWK Titan Suspension 7 06-29-2005 12:26 PM
Bilstein shocks? MaxPowers Titan Suspension 6 05-13-2005 03:27 PM
Need advice/comments about leveling kit for the Titan maestro Titan General Discussion 15 05-03-2005 07:17 AM
