Old 12-30-2005, 09:01 AM   #1 (permalink)
beached_titan's Avatar
driveshaft and cst lift?
any known issues with the driveshaft combined with the cst lift?
beached_titan is offline   Reply With Quote
Old 12-30-2005, 02:16 PM   #2 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Re: driveshaft and cst lift?
No, the cst 4wd kits use a staggered 4" block that works great. The 2wd CST kit uses the same block but has a carrier bearing drop down braket (the best int he industry, too bad the wont sell them without the kit) and there are no drivline issues unless you go taller than 4". At that point you need to use a tapred block.
Old 01-24-2006, 11:54 AM   #3 (permalink)
HemiHunter's Avatar
Mines out quite a bit from the transfer case....huh Greg.
04 KC 4x4 Galaxy Black
7" CST Lift, MX-6 Rear Shocks, PRG Sway Bar End Links and 4x4 Traction Bars, BFG A\T on Centerline Wheels. Radflow Coil-Overs.
Clarion Monitors, Eclipse DVD, Kenwood H\U,Sirius Satellite Radio
HemiHunter is offline   Reply With Quote
Old 01-24-2006, 08:08 PM   #4 (permalink)
Colorado_Titan's Avatar
What about the 4" block that comes with it and some Deavers? Will you run into a problem?
2006 Granite 4x4 LE Kingcab with Offroad package, Big Tow Package, and Power Captains.
Born: 9/05 Mine: 1/06
Colorado_Titan is offline   Reply With Quote
Old 01-24-2006, 10:47 PM   #5 (permalink)
Austin's Avatar
Add some big tires and you're sure to have a healthy amount of axle wrap... but that's easily fixed with a set of PRG traction bars.
MY04 SE King Cab 4X4 SOLD!
Driveshaft being replaced PittTitan Titan Problems & Dealer Service 5 10-18-2005 09:41 AM
Driveshaft Specs ecbmxer Titan Performance Modifications 3 09-04-2005 05:12 PM
2.5" lift Rough Country Lift for sale GETSOMZ28 Buy/Sell 0 10-26-2004 11:57 AM
Driveshaft Rusting Masa Titan Problems & Dealer Service 22 08-13-2004 11:01 AM
performance idea - aluminum driveshaft juma Titan Performance Modifications 18 08-12-2004 12:29 PM
