Old 02-13-2006, 02:58 PM   #1 (permalink)
Send a message via AIM to Timba24
Newb Questions on lifting titan
ok I have 4x2 titan and originally was going for a street truck but I have recently changed my mind to save up money for a lift kit nothing huge probably 4-6 inches. so here goes my questions
1. which lift would everyone recommend
2. I have done plenty of suspension work on imports so would it be a good enough idea for me to install the lift myself?
3. what kinda jack do you all use once your truck is lifted 6 more inches off the ground? does a standard floor jack work any more?
thanks in advance for the help
Timba24 is offline   Reply With Quote
Old 02-13-2006, 03:07 PM   #2 (permalink)
DaFridge's Avatar
Re: Newb Questions on lifting titan
i have been searching for the best do it yourselfer for remedially skilled like me. so far, the 4"performance kit has been winning the mind war when it comes to the pros and cons.
the hilift jack comes with various attatchments now to lift a truck. i have the one where 2 hooks lift up on your rims.
good luck
we're not here to start no trouble, we're just here to do the SuperBowl Shuffle!!"-1985 SBXX CHICAGO BEARS!!!!
2004 DEEPWATER
AEM BRUTE FORCE DRYFLOW
CUSTOM FLOWMASTER 40 DUAL THUNDER
T-MAXX OUTBACK WINCH
procomp stage2
PRG traction bars and endlinks
American racing mojave teflon 17s
35" XTERRAINS....these tires ROCK
safari softopper
Kc LIGHTS
www.off-road.com/nissan
DaFridge is offline   Reply With Quote
Old 02-13-2006, 03:11 PM   #3 (permalink)
thanks I am not too worried about the work it self as I have rebuilt multiple suspensions even turning some car from 4 lug patterns to 5 lug but I figured since I have never actually lifted a truck it would be best to ask questions lol
Old 02-13-2006, 03:58 PM   #4 (permalink)
Titan1080's Avatar
If you're changing a flat, you'll probably need a bumper attachment as well. I second the 4" Perfomance lift as you can buy and install it in stages, say start with mini lift (leveling kit with rear blocks), then add Deavers/TC uppers/Coilovers later.
AKA, Rusty Whore™
2004 Titan XE KC 4x4 DOB 12-15-2003
Compare your truck to mine and then kill yourselves!
Titan1080 is offline   Reply With Quote
Old 02-13-2006, 04:09 PM   #5 (permalink)
sounds like a good plan as I do like the ability to do it in stages
Old 02-14-2006, 07:53 AM   #6 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Any of the subframe type kits (cst, fabtech, pc, rancho) will only be few inches taller under the front x-member than a stock truck. The rear axle the same (just 1/2 the difference in tire height over stock) so any floor jack will work. jacking under the frame will be about 5" taller than usual.
Old 02-18-2006, 08:25 AM   #7 (permalink)
loufish's Avatar
Think about this...lift for the sake of lift is just bling-bling crap! The biggest tire the Titan should run is a 35", and all you need is enough lift to run them(4inchs). You should concentrate on ride quailty with better shocks and such.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
NEWBIE HERE: Questions about lifting, larger tires, and rims.......... kickinasphalt Titan Suspension 1 11-17-2005 07:42 PM
Have Tires, Custom Lifting Coils, Lifting Spacers For Sale neworleansmike Buy/Sell 3 02-18-2005 09:11 AM
Have Tires, lifting coils, and lifting spacers for sale... neworleansmike Buy/Sell 4 01-21-2005 07:33 AM
newb stereo questions titan44 Titan Interior Discussion 2 07-01-2004 11:26 AM
