Old 02-21-2006, 06:11 AM   #1 (permalink)
themaildude's Avatar
Pro Comp 6" lift. 2 Wd
I am thinking about doing the Pro Comp 6" lift myself. My questions are:
1. Are the 2WD kit and 4X4 kit the same?
2. Does anybody have the PDF file for 2WD installation directions?
3. How long did it take to install?
Thanks in advance.
IRC CREW MEMBER
Click Here For My Mods
themaildude is offline   Reply With Quote
Old 02-21-2006, 06:29 AM   #2 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Re: Pro Comp 6" lift. 2 Wd
Iv done 2 2wd titans in one day. I just did a 4wd in 3.5 hours start to finish. The only thing you will need is the carrier bearing drop bracket. That is by far the hardest part to install. I mod them and weld it in place, much stronger and eaiser maintenance. I might suggest a fabtech kit and cutting off the stock 4x brackets and addign braided brake lines, it will look much taller form the front (becasue of the shap of the x-member and if the brackets are cut off, it installs as easy as the pc kit. but the rear add-a-leafs suck.
Old 02-21-2006, 07:23 AM   #3 (permalink)
I never expected advice from the master. You doing 2 2wds in on day might equal me a 2 buddies struggling 2 days to lift my titan. Nevertheless I appreciate your words of wisdom. I just wish I lived closer to you, then I would never entertain the idea of "do it yourself".
When you speak of the fabtech kit "cutting off the stock 4x brackets" is that a part of the kit that you modify? If so, if I got the kit from you could this modification be done before shipping?
Currently I have the PRG 2.5" spacer up front, this is it has only teased me for wanting to do a full 6" lift.
I have plenty of tools and my mechanical skills are pretty good. It's just that I've never done any suspension work and wanted input on how hard it was/is.
Thanks Greg for your support hope you reply again.
IRC CREW MEMBER
Old 02-21-2006, 07:27 AM   #4 (permalink)
Hey Greg, for a GREAT DEAL I would consider:
1: Start out going NORTHEAST on CONYERS CT toward FAYSON CIR. 0.4 miles Map
2: Turn LEFT onto HOWLAND BLVD / CR-4145 W. 5.4 miles Map
3: HOWLAND BLVD / CR-4145 W becomes FL-472 W. 0.2 miles Map
4: Merge onto I-4 E via the ramp on the LEFT toward DAYTONA BEACH. 18.3 miles Map
5: Merge onto I-95 N via the exit on the LEFT toward JACKSONVILLE. 77.3 miles Map
6: Merge onto I-295 N via EXIT 337 on the LEFT toward ORANGE PARK. 20.5 miles Map
7: Merge onto I-10 W via EXIT 21B toward LAKE CITY / TALLAHASSEE. 505.8 miles Map
8: Take EXIT 267A-B toward I-12 W / HAMMOND / BATON ROUGE / I-59 N / HATTIESBURG. 0.2 miles Map
9: Merge onto I-12 W via EXIT 267B on the LEFT toward HAMMOND / BATON ROUGE. 85.2 miles Map
10: Merge onto I-10 W via the exit on the LEFT toward BATON ROUGE. 459.3 miles Map
11: Merge onto I-410 N via EXIT 581. 1.4 miles Map
12: Merge onto I-35 S / US-81 S via EXIT 31 on the LEFT toward SAN ANTONIO / BINZ-ENGLEMANN RD. 6.3 miles Map
13: Merge onto I-10 W via EXIT 156 toward EL PASO. 977.4 miles Map
14: Merge onto I-17 N / US-60 W via EXIT 150A toward FLAGSTAFF. 6.1 miles Map
15: Merge onto I-10 W via EXIT 200A toward LOS ANGELES. 292.3 miles Map
16: Merge onto CA-60 W via the exit on the LEFT toward RIVERSIDE. 17.9 miles Map
17: Merge onto I-215 S toward SAN DIEGO. 4.3 miles Map
18: Take the VAN BUREN BLVD exit. 0.2 miles Map
19: Turn RIGHT onto VAN BUREN BLVD. 5.1 miles Map
20: End at Woodcrest, CA US Map
Total Est. Time: 36 hours, 14 minutes Total Est. Distance: 2484.52 miles
IRC CREW MEMBER
Old 02-21-2006, 07:50 AM   #5 (permalink)
Supporting Vendor
P's Titan's Avatar
If you brought your buddies it could be a strate 36 hour trip. On the way back you always have Vegas as well
my mods list
USE DISCOUNT CODE FOLGER
FOR 10% OFF EVERYDAY @ www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 02-21-2006, 08:13 AM   #6 (permalink)
QWIKWHIP's Avatar
lol, now that's funny right there!
Old 02-21-2006, 10:29 AM   #7 (permalink)
Yeti77's Avatar
Yeah, and you could swing through Panama City FL too. It's just a little off of I-10.
2005 Blizzard CC, 4x4 Off-Road, Pop. Bench, Utility Bed, PRG 4" performance Lift w/ SAW's and TC UCA's on the front,Deavers and Radflo's on the rear, Custom Magnaflow exhaust, Fram Boost CAI, Nissan All-Weather Floor Mats, 315/70/17 BFG AT's on American Racing 17x8 Fuel 8 Teflon's, PIAA 40 series driving lights
Fir Na Tine
Yeti77 is offline   Reply With Quote
Old 02-21-2006, 02:11 PM   #8 (permalink)
You bet I could mod the kit before i shipped it to you. I could build you a complete custom package too. And i can give you credit on your leveling kit too. Give me a call 951 780-5331.
Old 02-21-2006, 02:17 PM   #9 (permalink)
Thanks Greg. I'm kinda just doing homework right now. Just spent $2,300 on tires, rims and bushwackers & paint figure it's gonna take me another 3-4 months to save up another 1500-2500 to get the lift started. I would like to give you a call though to plan out what I need to do in stages. I'll PM you.
IRC CREW MEMBER
6" Explorer pro comp lift kit aldaman Titan Suspension 3 12-08-2005 06:47 PM
6" Pro Comp/Fox lift by.......PRG of course! Pupule_04 Titan Suspension 11 12-03-2005 08:46 PM
Group Buy: Pro Comp 6" Lift - It's Official blachow Buy/Sell 21 04-24-2005 03:53 PM
Group Buy...Pro Comp 6" Lift blachow Titan Performance Modifications 0 03-11-2005 05:06 PM
Pro comp 6" lift TITANAK Titan Parts & Accessories 6 01-03-2005 01:48 AM
