Hey all, I was thinking about replacing the rear factory shocks (non-Rancho) with Rancho or something else. I looked in the service manual and it looks to be pretty straight forward. has this been the case for any of you that have switched out on your own. Also is this considered a 1 man job, or am I overly confident. What the manual says is listed below. Thanks for any tips.
SHOCK ABSORBER
RSU-7
RSU
Revision: October 2004 2005 Titan
SHOCK ABSORBER PFP:56210
Removal and Installation EES001CY
REMOVAL
1. Support the rear final drive and suspension assembly using a suitable jack.
2. Remove the shock absorber upper and lower nuts and bolts
using power tool.
3. Remove the shock absorber.
INSPECTION AFTER REMOVAL
Inspect the shock absorber for any oil leaks, cracks, or deformations. Replace the shock absorber as necessary.
INSTALLATION
Installation is in the reverse order of removal.
LEIA0104E
Shock absorber upper and lower nuts : Refer to RSU-5, "Components" .
2004 SE CC Smoke
Tinted front windows
K&N air filter
RF System
Utilitrack
Nissan hitch to complete the "little tow" package
Nissan fog lights added after purchase
If you drive on any type of dirt spend the extra 50$ and get premium shock such as a bilstein or pro comp. I took the stock ranchos off at 30k and they wouldn't even rebound after pushing the together. You will not be unhappy.
SHOCK ABSORBER
RSU-7
RSU
REMOVAL
using power tool.
INSTALLATION
LEIA0104E
driving my 4X2 and then driving a loaner with 190 miles on it...06 with 4X4 offroad package...WOW theres a difference...the 4X4 at least with me maybe others will say different but my truck rides WAY better than the rancho off road package....the shocks would even bottom out when my truck (4X2) wont...ride was WAY stiffer and uncomfortable...so unless ur practically gettin them free go for another shock...
like previously mentioned...Ive heard great things bout the billsteins...plan on gettin some myself (if not a whole lift package [4-6in])
SHOCK ABSORBER
RSU-7
RSU
REMOVAL
using power tool.
INSTALLATION
LEIA0104E
Easily a one man job. You don't need to jack the rear axle though, just make sure your p-brake is on and your tires are blocked. Just remove the bolts and replace the shock, easier than changing a tire. I got the Bilstein 5100s from PRG and they're great! They go for $190 a pair and will be perfect if you decide to lift your Titan.
I put the Blistein's on from PRG, love 'em! I have one arm and did it by myself, no problem.
Wow, you got 'er done with one arm? I MIGHT even be able to do this then.
2005 CC 4x4 SE,
Click Here for some useless Titan information from some idiot.
Adam AKA GoogleWhore™ Old people don't need companionship. They need to be isolated and studied so it can be determined what nutrients they have that might be extracted for our personal use.
Facts are meaningless. You could use facts to prove anything that's even remotely true! -Homer Simpson
300 is a great movie full of visual effects and graphics which made it different and much better.
Acting was great, director did a wonderful job and chose great actors, full of action, and it is based on a true story.
I went with the Donohoe Racing Rear shocks. Great ride when compared with the original ones.
Check out the Donohoes. Best person to ask is Greg @ PRG. He'll definitely steer you to the best setup for your tastes and requirements.
Hey numbnuts:
What has this got to do with rear shocks?
You're otta here!
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
OEM Rancho's = Crap shock painted white with a Rancho shock
Aftermarket Rancho's = A decent off-road shock.
But, I just got my PRG Shock kit. Sway-A-Way's with Total Chaos front Upper Control Arms. Donahoe Racing Rear shocks and Air bags.
