Old 03-22-2006, 08:37 PM   #1 (permalink)
d0va's Avatar
Unhappy Any One Experince Procomp Leveling Kit? ---how Hard Is It To Install A Leveling Kit?
Any One Experince Procomp Leveling Kit? ---how Hard Is It To Install A Leveling Kit? Pls Post Instructions
d0va is offline   Reply With Quote
Old 03-22-2006, 08:50 PM   #2 (permalink)
NorCal 4x4's Avatar
Re: Any One Experince Procomp Leveling Kit? ---how Hard Is It To Install A Leveling K
I believe they are the same as the Daystar level kits that are known for killing the OEM shocks. Here's a link to one of many threads that complain about this type of design. BTW the PRG design doesn't add this type of pre-load so doesn't have any of the bad side affects, and is much easier to install.
another daystar ?
Old 03-23-2006, 08:16 PM   #3 (permalink)
Re: Any One Experince Procomp Leveling Kit? ---how Hard Is It To Install A Leveling Kit?
I have it (it was a gift) and it was simple to install and I havent had any problems with it at all. The directions that come with it are pretty much right on just takes a few tricks that you will figure out as you go. Dont worry about a spring compressor because it wont help on this. Get 2 jacks, one to support the truck and the other to help compress the spring.
motoman139 is offline   Reply With Quote
Leveling kit install time??????? MansfieldTitan Prerunners.com - Titan Leveling Kits 41 11-12-2009 07:34 PM
Front end noise after leveling kit install MaxFax Titan General Discussion 8 01-18-2008 03:27 PM
help with prg leveling kit install J-Rod Texas Forum 6 03-10-2006 03:25 PM
HELP, Cannot install PRG Leveling kit Methu969 Titan General Discussion 7 03-24-2005 05:03 PM
How difficult is it to install a leveling kit? Jeostang Titan General Discussion 2 01-07-2005 06:40 AM
