Old 03-30-2006, 10:19 PM   #1 (permalink)
Mustard's Avatar
Total Chaos Install Question
Has anyone had trouble installing the grease Zerk's on the TC arm? I have a call into Greg but thought maybe someone else may have ran into this.
I can't get three of them started for the life of me. Also is the hole in the arm itself that the Zerk threads into tapered? The one I can get started stops after about 2.5 turns. If it's tapered I understand but with the trouble I am having with the others I thought I better stop and ask.
Installed the rear Deaver pack and Bilsteins tonight. Thankfully Greg told me to make sure I had C-clamps.
Thanks in advance
Regards,
Mustard
Mustard is offline   Reply With Quote
Old 03-31-2006, 02:48 PM   #2 (permalink)
smschulz's Avatar
Re: Total Chaos Install Question
Mine went in fine.
My truck is the same as yours only different.
PRG 4" Performance Lift
(DR's / TC / Deaver / Bilstein)
American Racing Chamber 18x9.5
Nitto Terra Graph 325/60/18
Banks / Zoomer tip / AEM
Truxedo Lo Pro
Bushwacker Flares
smschulz is offline   Reply With Quote
Old 03-31-2006, 08:30 PM   #3 (permalink)
Mustard's Avatar
Originally Posted by smschulz
Mine went in fine.
I think I figured out how to hold my mouth just right. How did you get the arms in place? I ground down the ridges on the frame where the arms bolt but still could not get them all the way in. Have not been able to get Greg on the phone so I just put the factory arms back on until I talk with him. Any help would be great.
Regards,
Mustard
Old 03-31-2006, 08:31 PM   #4 (permalink)
Jaybr's Avatar
I'm installing mine in the morning, hopefully no problems.
Jaybr is offline   Reply With Quote
Old 03-31-2006, 08:37 PM   #5 (permalink)
Mustard's Avatar
The drivers side rear bolt on the arm, Madonn'. I don't give up easy but I punted. I need to talk with Greg, I could not get the new arm to go all the way in to line up with the bolt holes.
Regards,
Mustard
Old 04-01-2006, 09:25 AM   #6 (permalink)
Jaybr's Avatar
Just finished the drivers side with no problems.
I put plenty of assembly lube on the outside of the bushings, and used a pry bar to slightly seperate the tabs a hair. Used a rubber mallet and tapped the arms in place, and a large punch to get the holes lined up.
Taking a coffee break then on to the passenger side.
Old 04-01-2006, 12:02 PM   #7 (permalink)
chunko's Avatar
what is this "coffee" you speak of? Is that some sort of foreign beer?
2005 CC 4x4 SE
AKA
TreeHuggingHippieWhore
"What if we picked the wrong religion? Every week we're just making God madder and madder." - Homer Simpson
chunko is offline   Reply With Quote
Old 04-01-2006, 12:18 PM   #8 (permalink)
Jaybr's Avatar
LOL, it was still early.
I finished the front with not too much trouble.
One thing I noticed when I put the tires back on and dropped the jacks was some fluid on the driveway. Crawled up under and saw the passenger side axle had slid out about an inch and was dripping. I pulled the tire back off and pushed it back in and it seemed to lock into place. Seems a little strange that it slid out that far, I didn't pull on the axle or spindle while the upper arm was off so it must have been pretty loose already. I thought there was some sort of retaining ring or something that held it snug, seems to have sort of locked back in now
The front is now a full 4" taller than stock with the DR's set at 2". Front is also taller than the rear now by about an inch. I'll install the Deavers this afternoon, just can't decide whether or not I want to install the lower shackles with them.
Old 04-02-2006, 02:02 PM   #9 (permalink)
Mustard's Avatar
I bet you get five bars of signal on your cell phone while in your house also.
I finally got them installed after talking with Greg and getting aggressive.
Regards,
Mustard
Old 04-02-2006, 04:31 PM   #10 (permalink)
Jaybr's Avatar
LOL, not quite. I get just enough signal for the phone to ring but not allow me to talk.
Glad you got them installed.
BTW, the shackles I installed today where worse than the arms.
Old 04-06-2006, 09:24 AM   #11 (permalink)
Wayne Kircher's Avatar
I too had oil coming out of the front diff when installing my 2" lift kit, as the axles do slide out very easy no clips. After realigning the front end the front diff needed about a pint of oil.
2004 LE 4X4 CC
Off Road Package
J&J z grill front end
2" lift Kit
Front 2" hitch mount for winch
Back up rear camera
Nissan Gas Assist Tailgate retro-fit
Born 06/30/2004
Purchased 10/30/2004
1200 miles changed to Synthetic oil "Mobil 1" in Engine
2500 miles changed to Synthetic oil in Rear end.
Wayne Kircher is offline   Reply With Quote
Old 04-11-2006, 11:12 PM   #12 (permalink)
Mustard's Avatar
I want to install the shackles since my rear is still a bit high. What was the problem installing them and did you learn a trick to make it easier on the rest of us?
Regards,
Mustard
Old 04-12-2006, 06:34 AM   #13 (permalink)
Jaybr's Avatar
The biggest problem with the shackles is just getting the hole aligned, on mine it was a PITA. I greased them good and used a floor jack on the axle to move them up and down, and a hammer.
Second thing is if you have the drivers side storage box, it has to come out, and removing it is not a lot of fun. After you get all the screws out of both brackets, there are plastic clips that you have to pop loose, 2 on top edge are difficult to get too.
Towing Report - Deavers and Fox Coilovers w/ Total Chaos Arms ptgarcia Titan Towing & Hauling 11 01-26-2006 10:16 AM
FS: Total Chaos Upper Arms Big-T Buy/Sell 9 01-15-2006 08:01 PM
PRG/Donahoes/Total-Chaos install... tortuga Titan Suspension 8 01-10-2006 05:52 PM
Longer Coil-Overs for Total Chaos? NorCal 4x4 Titan Suspension 2 11-01-2005 09:57 PM
prg rancho,fox,bils,deavers,total chaos lift doitbby Titan Pictures & Media Post 20 10-03-2005 08:07 AM
