Old 04-12-2006, 02:19 PM   #1 (permalink)
Yellomantis's Avatar
Question Best front leveling kit for 4wd
I'm new here, so I'm sure this topic has been beat to death. But which of the many front leveling kits is the most off road friendly? I have heard some of them can be quite noisy on the street. I am currently looking at the stillen and procomp kits. My only concerns are how will it affect my alignment and Will I need new shocks. I saw the procomp kit reccomends new shocks, but is it really needed? I have the off road package with the rancho shocks/struts. Also, how is the installation? I know the stillen kit just bolts between the strut ant the strut mount on the fender. Is the procomp the same way??? I would prefer something like that. With this lift, whats the max size tire I can fit without rubbing off road. If it dont rub off road it won't rub on the street right....I want to be running 33/12.5R17 or 35/12.5R17. Eventually I would like to be running on 38/15.5R18, but thats another subject. Glass fenders and all.
On a completely different subject.... Does anyone make a 4" lift spindle for the 4wd that's actually worth a pile o beans???
Thanks for the info,
Casey
Old 04-12-2006, 02:22 PM   #2 (permalink)
Re: Best front leveling kit for 4wd
Another thing, all I am really looking for is REAL ground clearance for the front. I dont want to have crossmember drop brackets defeating the purpose of the lift.
Thanks again,
Casey
Old 04-12-2006, 03:02 PM   #3 (permalink)
Supporting Vendor
P's Titan's Avatar
Send a PM to PrerunnerGreg or goto his website http://www.titanspecialist.com
You are local in so cali which is even better...
my mods list
www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 04-12-2006, 03:37 PM   #4 (permalink)
Mustard's Avatar
For the money the PRG 4" Performance lift is hard to beat plus if you want to go bigger you have a great foundation to build from. The link in the above post is where you get the kit I mentioned. Just in case you did not know.
Regards,
Mustard
Mustard is offline   Reply With Quote
Old 04-13-2006, 07:09 AM   #5 (permalink)
Thanks for the info, but I have a 4wd and according to the website, the lift spindle is for the 2wd.
Old 04-13-2006, 07:37 AM   #6 (permalink)
Supporting Vendor
P's Titan's Avatar
He has a 4wd 4" performance lift. PM him. there also was a recent thread about 4wd 4" lifts, I post some links in abit for you
my mods list
CrankyWhore™
TequilaWhore™
Old 04-13-2006, 07:40 AM   #7 (permalink)
Supporting Vendor
P's Titan's Avatar
here's one 4" Performance Lift w/ 35's Pic Request
another one... PRG 4" Performance Lift
my mods list
CrankyWhore™
TequilaWhore™
Old 04-13-2006, 09:25 AM   #8 (permalink)
Wallrat's Avatar
If you're just trying to lift the front end to level out the truck then Greg has a little mini lift that you can install. Its super simple - basically just some 2" thick billet aluminum blocks that fit between the shock upper and coil bucket, plus some new bump stops. I'm running that until I save up the green to do a 6". His website doesn't have everything that he carries so its best to send him a PM or call.
-Anytime you lift you're going to need an alignment.
I've got feeler gauge fingers, torque wrench wrists, and a timing light eyeball!
05 SE KK 4x4
offroad, big tow, buckets, util.
$$$ stereo
Pro Comp 6", Dre's/Bilsteins, PRG Traction Bars
315/70 17 BFG AT KO on 17x9 AR Chambers
Wallrat is offline   Reply With Quote
Old 04-13-2006, 09:43 AM   #9 (permalink)
helomech's Avatar
I think the mini lift lifts the back also. If you just want to level then you need to order just the level kit.
helomech is online now   Reply With Quote
Old 04-13-2006, 04:37 PM   #10 (permalink)
Casey
The best way to go to just level it is the spacers, However if you do any offroading then go for the DR coilovers or you will blow the front shocks in a matter of time. This comes from experiance, The factory shocks are junk so just save up and get the coilovers and Bilsteins for the rear and your good to go.
KT
2005 XE CC 4x4 Smoke
ktee is offline   Reply With Quote
Old 04-16-2006, 08:00 PM   #11 (permalink)
Supporting Vendor
P's Titan's Avatar
KT
Like said before, PM Greg tell him what your looking for and he will give you your options. As you have most likely read on this Site, he is a very honest guy who will not BS you.
my mods list
CrankyWhore™
TequilaWhore™
Old 04-17-2006, 09:16 AM   #12 (permalink)
KTMNealio's Avatar
Send a message via AIM to KTMNealio
FYI: Most "leveling kits" are just a block of metal you bolt to the top of your strut assembly..
2005 SE - Smoke CC 4x4
My Titan's wheels and tires
KTMNealio is offline   Reply With Quote
Old 04-22-2006, 10:28 AM   #13 (permalink)
got_titan's Avatar
dr's are the way to go! call greg, he has talked to me on several occasions for 30-45 minutes just to make sure he has answered all my questions and given me the best product for my application....just call him, probably the most knowledgable suspension person i have ever talked to and he only sells the BEST products. if you can swing the dr's you will not be dissapointed!
04 cc 4x4 w/big tow...........silver
volant cold air , oem sirius tuner, Zoomers exhaust, wade in channel visors, chrome tailgate piece ,05 finned diff cover,leather console lid, tailgate torsion bar,22 inch akuzu bounce, 305/45/22 nitto 420 extremes, mccullough hid's,05 active headrests , truxedo low profile,stillen front sway bar, painted lund interceptor, cr lawrence rear power slider,armada painted front spoiler, dr coilovers, t rex vertical billet grill, zoomers exhaust, prg traction bars, brake pros monster brake kit, prothane front swaybar bushings, volant vuelights(led), odyssey deep cycle battery, trutrac on order.....(INSTALLED)
STILLEN SUPERCHARGED 425rwhp 431rwtq (before headers)
Old 04-22-2006, 02:46 PM   #14 (permalink)
Thanx alot for all your help guys!!! For now I will be buying the stillen kit, but future plans call for the prg kit. I have some things for sale in the for sale section by the way. later!
Casey
Old 04-22-2006, 04:49 PM   #15 (permalink)
NorCal 4x4's Avatar
The PRG level kit is $10 cheaper, includes shipping, and includes bumpstops.
Follow the link in post #3, or my sig, then select suspension tab on the left. 1st item are the level kits. The 2" one is for the 4X4 and 2.5" kit is for the 2wd Titans.
Silver '04 Titan SE Crew Cab 4x4 w/E-LOCK® - Born on 05/18/04 in the USA ... 33.5" Toyo M/Ts;
Front end noise after leveling kit install MaxFax Titan General Discussion 8 01-18-2008 02:27 PM
Front leveling Kit (4wd) aldaman Titan Suspension 9 03-27-2006 05:49 AM
Front-end alignment problems with the 2.5" leveling kit... miketan Titan General Discussion 6 02-04-2006 09:48 AM
prg 2" leveling kit for the front end FOR SALE repsolman Buy/Sell 2 07-18-2005 04:29 PM
For advertising information, please visit our
