Old 04-15-2006, 09:36 AM   #1 (permalink)
Remove front sway bar on lifted Titan, Yes or NO?
I guys, I have a rancho lifted titan, and the front sway bar endlinks keep giving me trouble and bolts keep falling off and making weird noises...
What are the pros and cons of removing the sway bar vs keeping it?
THX in advance..
Suspension Mods:
BFG MT/KO 35"x12.5"r17
Audio Mods:
Cooming soon:
HIDs and Yellow Fogs...
Old 04-15-2006, 12:19 PM   #2 (permalink)
Mustard's Avatar
Re: Remove front sway bar on lifted Titan, Yes or NO?
I have Greg's 4" kit and love the way it handles without the sway bars. The Rancho is a lot taller so the increased center of gravity may make it to unstable without bars. What are you running for coilovers?
Regards,
Mustard
Mustard is offline   Reply With Quote
Old 04-15-2006, 01:29 PM   #3 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
THe biggest difference is that Mustard is running a higher spring rate and will have less sway than k-mu. But k-mu, the ride will be better w/o the sway bar but you will notice the truck will lean a bit more in the corners, but it wont be bad. Its free to try and i assure you that nothing terrible will happen. Just remove the endlinks and give it a drive.
Old 04-16-2006, 08:12 AM   #4 (permalink)
Ive driven the truck without one of the endlinks on and didnt notice anything bad in handling, would it be the same without both endlinks?
should I completely remove the swaybar or just the endlinks and keep the sway bar floating around?
How would the removal of the swaybar improve the offroad handling?
THX in advance
Suspension Mods:
Audio Mods:
Cooming soon:
Old 04-16-2006, 10:06 AM   #5 (permalink)
Austin's Avatar
I pulled mine off. I only notice it when I lapse back into my autocross days.
Like Greg said - it's free to try. Do it, and if your truck leans too much in the corners for your liking, undo it.
MY04 SE King Cab 4X4 SOLD!
Old 04-16-2006, 11:14 AM   #6 (permalink)
Having one link undone is the same as both. What you felt is the same as removing the whole assembly.
Old 04-16-2006, 06:30 PM   #7 (permalink)
ptgarcia's Avatar
I used to forget to reconnect the links on my Toyota after a day of wheelin' and never notices a difference. I know the Titan is a different truck but I doubt you'll notice.
By disconnecting it you get better articulation when offroad. I say go for it.
Pauly
Old 04-16-2006, 06:42 PM   #8 (permalink)
Mustard's Avatar
I don't know about won't notice. The day after my sway bar was off I took an off ramp to fast and about scared the.... well you know out of me. Once I regrouped my thoughts it was OK just different than what I am use to. It leaned more than usual but once it went so far it was solid. But like I said before, pot holes and big bumps you hit at an angle are so much better.
It's been well over a week now with sway bar removed and I like it much better without the bar.
Regards,
Mustard
Old 05-09-2006, 08:51 PM   #9 (permalink)
EPTITAN's Avatar
Location: some where between bum f&*$ Egypt and you got a pretty mouth
I am considering doing this also, K-MU what did you decide to do?
EPTITAN is offline   Reply With Quote
Old 05-10-2006, 09:48 AM   #10 (permalink)
Been without the swaybar for a while now and liking it...
Suspension Mods:
Audio Mods:
Cooming soon:
Old 05-24-2006, 11:37 PM   #11 (permalink)
kartman's Avatar
I disconected mine. Significantly more body roll but lots more sterring. I do get more inside tire lift on the rear when cornering hard but otherwise I like it.
Rebar Wrangler
Old 05-27-2006, 04:05 PM   #12 (permalink)
quiksilver titan's Avatar
KMU ,
Did you completely remove the sway bar or just remove the endlinks and leave the sway bar floating. I completely removed the sway bar today and my initial impression is that I like it a lot. Much smoother over small bumps and my steering feels easier. Any how just wondering if I should have not removed the entire sway bar for any reason. Please chime in PRG if you are reading..
quiksilver titan is offline   Reply With Quote
Old 05-27-2006, 09:50 PM   #13 (permalink)
Chris93Si's Avatar
Send a message via AIM to Chris93Si
Having the endlinks off would be the same as having the bar off completely. All it's doing w/o the endlinks hooked up is adding dead weight
So yeah, you're fine w/ it off.
When someone smiles at me all I see is a chimpanzee begging for its life.
My wheels for sale!
bustedshocks
P1 Auto
PRG
Chris93Si is offline   Reply With Quote
Old 05-28-2006, 08:15 AM   #14 (permalink)
Thanks for the reply!
Old 05-28-2006, 09:22 AM   #15 (permalink)
Banned
ChicksDigEmToo's Avatar
I too am running without the sway bar...I seem to do just fine and from what Greg says the ride is better! Dead weight is my opinion also.
ChicksDigEmToo is offline   Reply With Quote
front sway bar bushings toadvb20 Titan General Discussion 3 07-31-2008 03:42 PM
rear sway bars and lifted trucks... OCtitan99 Titan Performance Modifications 1 01-06-2006 09:22 AM
How do you Remove front bumper? dalt1 Titan FAQ & Howto Area 8 08-20-2005 03:48 PM
How do I remove the Titan Emblem from the front? Methu969 Titan General Discussion 4 03-17-2005 05:57 AM
Front Sway Bar Adjustment???? honeykeeper Titan General Discussion 18 01-13-2005 07:07 AM
