Old 04-15-2006, 10:54 AM   #1 (permalink)
DWC5X5's Avatar
New shocks and Alignment?
Im getting the new Rancho Triple x shocks and was told that installation was 200 dollars and a alignment was 98. Question is- 1.Do I really need to get an alignment for only putting on the front shocks? 2. Can I install these by myself? I am pretty mechanically inclined, Ive changed shocks and other things on my cars and Im good with Motorcycles. Do I stand a chance on doing this on my own? Thanks.
DWC5X5 is offline   Reply With Quote
Old 04-15-2006, 11:15 AM   #2 (permalink)
Chris93Si's Avatar
Send a message via AIM to Chris93Si
Re: New shocks and Alignment?
Yes you'll probably need an alignment.
It shouldn't be extemely hard to install yourself. Your using your stock springs and upper mounts right? You'll need some common hand tools and a set of spring compressors (can pick those up at Autozone for $30).
When someone smiles at me all I see is a chimpanzee begging for its life.
My wheels for sale!
bustedshocks
P1 Auto
PRG
Chris93Si is offline   Reply With Quote
Old 04-15-2006, 11:25 AM   #3 (permalink)
DWC5X5's Avatar
Cool, Im gonna give it a shot! If all else fails I will just take them into the shop and have them put the springs on for me. Wasnt sure about the alignment tho! Thanks for the reply.
Old 04-15-2006, 01:31 PM   #4 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
You WILL need to adjust the toe, mandatory if you raise it at all.
Old 04-15-2006, 01:40 PM   #5 (permalink)
troutking's Avatar
Location: Squarefield Ca. Make a right at the budwieser brewery and just past the Jelly Belly factory.
Greg is toe when the wheels look like the back of a baja bug? I put your leveling kit in my 4x4 and have this effect. Haven't had the alignment checked yet. If I take the blocks out and buy the DRs and crank them up to 2.5 or 3 inches will I need the alignment done again. I would guess yes.
troutking is offline   Reply With Quote
Old 04-15-2006, 02:50 PM   #6 (permalink)
I just got a set of Greg's Bilsteins for the rear of my Titan and the install was a snap. I had a 4X4 shop put on my front end spacer and it amounted up to a remove and replace of the front shocks. It seems like they charged me 35.00.
After seeing was it entailed I could have easily done it myself. BTW- I did have to be aligned.
rico387 is offline   Reply With Quote
Old 04-15-2006, 06:17 PM   #7 (permalink)
got_titan's Avatar
i have the complete rancho triple x system for sale with coilovers if you are interested?? its in the for sale section and everything is complete so it will save you time and money.....
04 cc 4x4 w/big tow...........silver
volant cold air , oem sirius tuner, Zoomers exhaust, wade in channel visors, chrome tailgate piece ,05 finned diff cover,leather console lid, tailgate torsion bar,22 inch akuzu bounce, 305/45/22 nitto 420 extremes, mccullough hid's,05 active headrests , truxedo low profile,stillen front sway bar, painted lund interceptor, cr lawrence rear power slider,armada painted front spoiler, dr coilovers, t rex vertical billet grill, zoomers exhaust, prg traction bars, Stillen brake pros monster brake kit, prothane front swaybar bushings, volant vuelights(led), odyssey deep cycle battery, trutrac on order.....(INSTALLED)
STILLEN SUPERCHARGED 425rwhp 431rwtq (before headers)
Old 04-15-2006, 07:53 PM   #8 (permalink)
troutking, that is camber (the vw effect). you may need that adjusted, but usually not. If the toe (parallelism) that will also have a megative effect on the camber. If the wheels are toe'd in (as would be the case with any leveling kit) the wheel will want to "climb" and will actually rasie the truck and it will want o force the bottom of the wheels toward each other.
Alignment After PRG JerseyTitan Titan General Discussion 4 08-30-2005 07:21 AM
Alignment always necessary after PRG? engine17 Titan Suspension 7 08-14-2005 07:00 PM
Alignment?? jd1973 Titan Wheels, Tires & Brakes 6 08-11-2005 05:59 PM
alignment 6thsense Titan Problems & Dealer Service 3 12-30-2004 06:14 AM
PRG Kit and Alignment ? TITAN4x4 Titan Suspension 4 12-26-2004 07:44 PM
