Old 04-15-2006, 11:10 AM   #1 (permalink)
Chris93Si's Avatar
Send a message via AIM to Chris93Si
Who's lifted and still towing???
I'm considering a PC 6" lift and am wondering how much it will hinder my towing ability (if at all). I haven't towed anything yet but I'd like to be able to tow my car on a trailor in the future, I'm assuming it'd weigh around 5-6k pounds. Will I still be able to do this lifted? Am I going to need to invest in airbags? I tried searching for info on this topic but couldn't find anything. Any help appreciated
When someone smiles at me all I see is a chimpanzee begging for its life.
My wheels for sale!
bustedshocks
P1 Auto
PRG
Chris93Si is offline   Reply With Quote
Old 04-15-2006, 12:23 PM   #2 (permalink)
HVACman's Avatar
Re: Who's lifted and still towing???
i tow my 5000 pound jeep with my 7in lifted titan. it isnt much different, you'll just get 8-9 mpg on 35's
Titan CC LE 4x4 Radiant Silver * Born 4/16/04 * Big Tow / Offroad Package * Kenwood DVD/NAV ent. system * Infinity 6000cs Component Speakers * Infinity 7540A Power Amp * SPL Sub Power Amp * 2 10" PowerBass Subs * Tsunami 1-Farad Capacitor * JBA Ceramic Coated Headers * Flowmaster 40 Series Catback System * Sirius Satelite Radio * K&N 77 Series FIPK Intake System * Airaid Throttle Body Spacer * Really Loud Air Horns * Weld Racing Cheyenne Rims * Carbon fiber dash kit * Black billet grille * Truxedo Tonneau Cover * CST 7" Lift * ProComp XTerrain 35/12.5/17 Tires * Procomp Traction Bars * Stainless Steel Brake Lines
Wherever you go, there you are
HVACman is offline   Reply With Quote
Old 04-15-2006, 01:25 PM   #3 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
I toww my other titan and iits fine. Your springs will be the same as stock, the blocks will add more axle wrap though.
Old 04-15-2006, 02:58 PM   #4 (permalink)
bigblue06's Avatar
Procomp traction bars would fix the axle wrap problem wouldn't it.
bigblue06 is offline   Reply With Quote
Old 04-15-2006, 04:41 PM   #5 (permalink)
rcantu's Avatar
I'm going to tow a honda accord from AZ back to So Cal.
pics of the Titan
Old 04-15-2006, 05:57 PM   #6 (permalink)
CoachBoone's Avatar
Hey Greg, thanks for the quick shipment on my "stuff". I got the Deavers and Bilsteins, but I'm wondering if I keep the 1.5 blocks on the rear with the leaf spring pack lifting it up a bit more, will the traction bars negate any axle wrap that might cause? Or would it be best to lose the blocks to avoid axle wrap altogether? Also, why do you recommend losing the front sways with the Donahoes?
forget the sway bar question, just saw your previous post.
Dan
2004 Nissan Titan SE 4X4 Crew Cab
with a bunch of stuff on it.
"Straighten that tie, son."
Old 04-15-2006, 07:58 PM   #7 (permalink)
I dont "recomend" removing the sway bar, but i recomend trying the ride without it. Its free to try and you may like the results. As for the block and spring, i think it will be too tall. And yes, the traction bars will really help with towing. I recently had a guy with a CST kit who tows a big-o toy hauler and he had major vibration issues and we instlaled the traction bars and all the axle wrap/ vibration issues are gone.
Old 04-15-2006, 09:01 PM   #8 (permalink)
CoachBoone's Avatar
Thanks for the advice. I'll try the Deavers alone and then see what it's like. My issue is I like the oem rake and wouldn't mind bringing her azz up a little more with the 2.5 front coilovers. We'll just play with 'er a bit and see.
Old 04-15-2006, 11:02 PM   #9 (permalink)
DESERTDOG's Avatar
i still tow all my toys some big some small not to much difference no big tow xe crew 4x2
dude don't worry my dad's a plumber "i can fix it!"
DESERTDOG is offline   Reply With Quote
Old 04-16-2006, 08:48 PM   #10 (permalink)
rcantu's Avatar
ok I just used a Uhaul tow dolly to pull a 91 honda accord. it was fine except for some uphill spots it didn't downshift and my trans guage was showing it was getting hot. Going 75 at ~2700 rpm didn't do well. When it shifted to 3700 or so the trans cooler when back to normal. I need to get some big brakes. My tires degrade the brake strength.
pics of the Titan
Old 04-16-2006, 11:55 PM   #11 (permalink)
Nissan Mike's Avatar
I've got the Pro Comp 6" with 35's I ended up adding Firestone Air Bags by Ride Rite because I don't like any squating when I'm towing my boat.
Note I am using the stock springs with a 3" spacer underneath maybe the Deavers won't have this problem?
I like the adjustibility of the air bags.Just remember if you are using spring spacers you will also need "cans" which are round metal spacers the exact height of your lift blocks to put under your air bags.Otherwise they don't fit!
As far as towing I'm only pulling about 4500 pounds on a tandem axle trailer so not a problem but I'm confident I could tow at or near capacity with no problems at all.
Wherever you get your lift kit should help with the bags and cans,if not I got mine at 4 Wheel Parts for about $260.00?
Remember if you have the Big Tow Package your 3:36 gears are equal to
4:10's with the 5 speed trans.When changing to 35" tires you will then be running around an effective ratio of 3:80 and speedo will be off {showing slower}by about 5%
Just go for it You'll be glad You did!
Old 04-17-2006, 12:08 AM   #12 (permalink)
Colorado_Titan's Avatar
I towed this weekend with my PC lift. No differance, but you should get about a 5 inch drop down hitch. I didn't have one and used my regular one, and there was a pretty big angle on the hitch. I am going to buy a bigger drop down one before I tow again.
2006 Granite 4x4 LE Kingcab with Offroad package, Big Tow Package, and Power Captains.
Born: 9/05 Mine: 1/06
Colorado_Titan is offline   Reply With Quote
Old 04-19-2006, 10:45 PM   #13 (permalink)
DStewart's Avatar
Do you have the bags that mount to the frame and axle or the bags that mount between the frame and leaf springs?
SOLD:2004 Nissan Titan 4x4-Smoke, Big tow, SE bed package, Popular package w/ captains chairs.Mods: updated aluminum rear diff cover, K&N drop-in filter, PRG lift, Firestone air bag kit, 17x9 Eagle Alloy 101's, 295/70R17 Nitto Terra Grappler, polished Billet grille-upper 3 piece and lower.
2005-FS2600 Weekend Warrior toy hauler
05 Honda CBR 600RR Black/Gunmetal w/Tribal Flames
DStewart is offline   Reply With Quote
Old 04-20-2006, 04:51 AM   #14 (permalink)
QWIKWHIP's Avatar
I haven't hitched up my camper yet since the trucks been lifted, however, I had 800 lbs of concrete in the bed last week and the truck only sagged about 1.5". That's with a 3" block and the Deaver mini pack. So my camper should only sag an inch or less. I'll know for sure next week though. Gotta take the camper in to get a state inspection.
Old 04-20-2006, 05:41 AM   #15 (permalink)
ecbmxer's Avatar
From what I have read, the speedo will correct itself after a bit of driving. Somebody else correct me if I am wrong.
2005 Titan SE 4x4
Floor Mats
Splash Guards
Nissan Drop-in Bedliner
Front windows tinted to 35%
In-Channel Vent Visors
Front Husky Liners
STEREO:
Pioneer DEH-P8MP Head Unit
ecbmxer
ecbmxer is offline   Reply With Quote
Disappointing Hemi towing experience (from towing forum) karlconnell Titan Towing & Hauling 11 12-19-2007 06:48 AM
9600 lbs towing! try 17000 lbs towing standingtall Titan Towing & Hauling 1 12-08-2005 04:48 AM
Just Lifted need help DWC5X5 Titan Suspension 10 07-22-2005 11:38 AM
Towing experts: Question about towing long trailer ptgarcia Titan Towing & Hauling 15 04-18-2005 01:03 PM
I'm getting LIFTED!!! galaxycrew Titan Performance Modifications 2 01-18-2005 01:57 PM
