Old 04-22-2006, 07:36 PM   #1 (permalink)
Icemanrulz's Avatar
Send a message via Yahoo to Icemanrulz
Pro Comp 6" question...HELP
Well spent most of the day trying to do this on my own... OK so far I guess.
Well I am at the "transfer the parts from the old knuckle (spindle)
So how do you get the hubs out? I don't want to break anything?
Thanks!
Steve
Icemanrulz is offline   Reply With Quote
Old 04-22-2006, 10:34 PM   #2 (permalink)
SmokenMini's Avatar
Re: Pro Comp 6" question...HELP
I had the same problem. I had to call PRG and ask him how he does it. He said that he just unbolts the three bolts that hold the hub in (obvious) and then smacks the hub with a RUBBER mallet. I had tried this until my upper half was sore then I took it to the neighbors and put it in his hydro press. After pressing them out, I realized that I could have smacked them for 5 days with the mallet and they wouldnt have came out. It sounded like a shotgun blast when they finally popped loose. My truck had about 15K on it when I did my lift so if yours is newer, maybe you could break them loose with a mallet? Myself, I would just get them pressed out.
2005 Smoke CC BT OR
ProComp Stage 2
PRG Leveling
Deaver Full Spring Pack
Total Chaos upper arms
20" Moto Metal 951's
36/13.50/20" Irok Radials
Husky Liners
Lund Stainless Hood Guard
Lund Tri-Fold Tonneau
Rear diff's be ware....I will break you
Because lifes' too short to drive an ugly truck...
SmokenMini is offline   Reply With Quote
Old 04-23-2006, 05:39 AM   #3 (permalink)
Icemanrulz's Avatar
Hmm I guess I could try pounding on them. Maybe Pep Boys would pop them out for me. Thanks!
Old 04-23-2006, 08:51 AM   #4 (permalink)
ohiodish's Avatar
I used a press to get mine out. Greg must have Superman stregth to get them out with a rubber mallet.
*****God put me on this earth to accomplish a certain number of things....and right now...I'm so far behind I will never die.*****
'04 CC, DVD, NAV, XTANT 4.4 (4 ch. 400 watt) & 6.1 (monoblock 600 watt) amps, JL CS, AudioControl DQS EQ, Two JL Audio 8W7's in a Elegonics enclosure, MB Quart "Q" series 6 1/2" front doors, MB Quart Reference 6 1/2" set rear doors, FATMAT sound deadning, Ipod through JL CS via Scosche IPBCK Bluetooth wirelss transmitter, OPTIMA Yellow Top.
Glassworks Hood
Bushwacker painted flares
NISMO C/A intake (ebay)
Borla dual cat back exhaust (ebay)
Street Scene Chrome Speed Grille & Valance
Pace Edwards Bedlocker (power tonneau)
Procomp lift kit (PRG)
Donahoe Racing front coilovers (PRG)
Bilstein's rear (PRG)
Total Chaos Upper Arms (PRG)
Deaver spring upgrade (PRG)
Weld Racing Velocity 6 XT 18"x10"
Mickey Thompson Baja Radial ATZ 35x13.50x18
Chrome tailgate trim (ebay)
Bermuda Black altezza tail lights (ebay)
PRG Traction Bars
N-Fab Nerf Bars
THANKS GREG!
ohiodish is offline   Reply With Quote
Old 04-23-2006, 05:53 PM   #5 (permalink)
Icemanrulz's Avatar
You got that right! The Gods are with him too. I broke mine...then went to a tire shop and paid them to press them out.
Got the front done. I think I am going to fab up a new skid plate though.
Old 04-24-2006, 07:29 AM   #6 (permalink)
QWIKWHIP's Avatar
I wacked mine out with a rubber mallet also. They were tight, but they came out.
A Question about Pro Comp lift DWC5X5 Titan Suspension 3 04-13-2006 07:44 AM
Finally Pro Comp Xterrains in 33"x12.5"r17... K-MU Titan Wheels, Tires & Brakes 3 09-28-2005 01:51 PM
6" Pro-Comp 3" PA Body 38x15.50r20 Finished(almost) brooke1lyn Titan Performance Modifications 22 06-16-2005 04:02 AM
Question about poping noise after 6" pro-comp lift bristolVATiTan Titan Suspension 5 05-10-2005 10:06 AM
Pro Comp 6" / CST 8" what is the true hight. RCtitan04 Titan Suspension 4 01-07-2005 07:17 AM
