Loud clunking noise in front end passenger side HELP!!! - Nissan Titan Forum
post #1 of 6 (permalink) Old 06-17-2017, 10:29 AM Thread Starter
iTrader Score: 0 reviews
Exclamation Loud clunking noise in front end passenger side HELP!!!
I have a 2006 Nissan Titan SE. A few weeks back I changed and replaced brakes and rotors all the way around. Shortly after I noticed a slight clunking noise that I chalked up to being bad struts. I bought and replaced the front with quick struts thinking that would solve my problem. It didn't. Instead the clunking noise has become louder. Every little bump or pot hole I hit you can hear something clunking/banging around in the front end on the passenger side. I've climbed under there and can't seem to pin point where the noise is coming from. It's gradually become worse and now I have a slight vibration in the steering wheel as well. I can literally feel the road beneath my feet as I'm driving it through the floor boards. It has become so bad that I don't want to continue driving it until I figure out what's going on with it. Any advice would be greatly appreciated. If I can't get this figured out soon, off to the Nissan dealership it'll go to get diagnosed.
Chall is offline
Advertisement
post #2 of 6 (permalink) Old 06-17-2017, 11:46 AM
FishnAlaska's Avatar
Garage
iTrader Score: 3 reviews
Re: Loud clunking noise in front end passenger side HELP!!!
Could be LCA ball joint or bushings, UCA ball joint or bushings, sway bar end links, sway bar bushings... that is where I would start.
2010 Titan 4x4 CC SE Majestic Blue
Uprev tuned by Seymore, JBA Evol catback, Cajun catless B pipes, Airaid MXP 4" CAI
8" Boston acoustic's sub in Tech12volts ported box w 1000 w renegade amp
Autostart remote start, bedlined OEM wheels, bumpers, and grill. Go Rhino D2 steps.
Pyramid Automotive Retro fit headlights with Xenonvision H1 Hid's and super bright LED reverse lights, blue interior LED's, and white exterior LED's.
Smoke hood shield and in channel window deflectors, Custom grounding kit by FAK.
Pro4X skid plate, 20" double row Cree light bar, rear bumper flushmount Cree LED's
Leer 100R Topper, Goodyear Duratracs 275/70/18,
Dirt King UCA's, Bilstein 5100's mid setting and 1.5" spacer, 1.5" rear block w/Bilstein 5125's.
FishnAlaska is offline
post #3 of 6 (permalink) Old 06-17-2017, 12:47 PM
Since the brakes are the last thing done before this started, that's where I go back over my work......If you reused the hardware on the old calipers, check to see if that isn't the problem. Sometimes old hardware doesn't hold the pads well enough and noises are the result. Also, make sure the pad tabs and slider pins were well lubricated with the correct grease. Were the pads made with anti chatter backing, if not, you may need some of that in liquid form (permatex makes it) to reduce that possibility as well.
Or as Fishn said, it could be something a lot more expensive and harder to find.
Nick Name is offline
The Following User Says Thank You to Nick Name For This Useful Post:
honda250xtitan (06-17-2017)
post #4 of 6 (permalink) Old 06-17-2017, 01:45 PM
honda250xtitan's Avatar
Garage
iTrader Score: 9 reviews
Id also start with the brakes. Check the big 17?mm bolts especially. you can do that with the truck on the ground and tires still mounted.
2011 White CC Pro4x
All the things Build Thread:
DIRT KING FABRICATION, FOX, TOYO, FUEL, PRG, GIBSON, BORA, AIRAID
Now stock AF
Traded In: 06 KingCab 4x4
Don't be a dummy, use this before asking
honda250xtitan is offline
post #5 of 6 (permalink) Old 06-17-2017, 09:34 PM Thread Starter
Thanks for the feedback. I ended up getting it into a shop where they checked it out for free. Lower control arms and ball joints on both sides are shot. Going to pick up parts tomorrow and change them out. Hoping that's it. I'll keep you all posted
Chall is offline
post #6 of 6 (permalink) Old 06-27-2017, 03:30 PM Thread Starter
Update-
Got the lower control arms replaced and the noise stopped for a day or two and was right back. Went and bought sway bar links and bushings and that seems to have solved my problem.
Chall is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Loud noise coming from front end while coasting (video link) avmaldo Titan Problems & Dealer Service 5 10-22-2015 08:58 PM
Clunking noise coming from front end Christopher Sweetman Titan Suspension 5 05-15-2015 03:25 PM
Loud clunking noise...need help TheTitan_Kronos Titan General Discussion 6 02-03-2015 06:07 PM
Clicking noise on the front passenger side BEEMSANG Titan Problems & Dealer Service 1 07-29-2008 06:04 PM
Front Passenger Side Bumper End billgriffith Titan FAQ & How to Area 1 08-20-2007 03:02 AM
You may post new threads
You may post replies
