Re: Rear Springs squeaks
If it has leaf springs, it will eventually squeak. Get some teflon based (PTFE) spray lubricatant from your local auto parts store. "Fabulous Blaster" is one brand that I have used. Take an old towel and soak the springs between each leaf then wipe off the excess with towel. The teflon based lube will dry and will not attract as much dirt. My personal experience is, one treatment lasts about 3-4 months. but I'm sure your enviroment (wet VS dry) will play a factor in how long you can go between lubing. The helper springs, only make more noise. The helpers have a retention strap that goes over top of the leaf pack. That bracket makes a racket over small bumps. I had a Dodge before the Titan and it had the same squeaks
Boone-Titan
Radiant Silver LE, CC, 4WD, Big Tow,
DVD, Side Air Bags, LowProTruxedo,
Bed Extender, Vent Shades, Lund Bug Shield,
Bed Tube Rails, Street Scene Grills, KC Slimlites,
Auto Tailgate Lock, Aux Back Up Lights
