Old 09-01-2006, 08:29 PM   #1 (permalink)
Smile procomp 2.5" lift
i just got a new titan on sunday and i love the truck. traded in my lifted 04 chevy wanted something with more power . i installed a procomp 2.5 lift today took just over an hour to do . the kit has two spacers one that goes between the frame and top of strut . the other one goes between the coil spring and strut plate. i have been reading these forums for about 5 days so i thought i would listen to you guys . i didnt want to break my struts do to the spacer between the coil spring . i didnt install that spacer, just the spacer that goes above the strut. damn it looks great and rides just like stock, no spring bucket hitting the arm and no strut knock..
if you do a front lift make sure you have a good coil spring tool . the coil springs are firm and almost dont move . i can see why with the spacer added it would break the strut .
06 chevy killer is offline   Reply With Quote
Old 09-02-2006, 07:10 AM   #2 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Re: procomp 2.5" lift
The bolts that you ran thorough the upper plate will always loosen and leave you with noises. and you will loose about 1/4"-1/2" of lift per year until the bushing is about 1/2 its height now. and if you over tighten the bolts it will deform the coilbucket. just a heads-up.
Old 09-03-2006, 12:36 AM   #3 (permalink)
greg knows his stuff and his advice are awesome........
PRG Performance package lift: Donahoe
Racing coilovers front/radflo rear/rear Deaver mini-pack with 4" block/4" CST Spindle Lift/20x10 Moto Metal 951s on 35 x 12.50 x 20 Nitto Mud grappler/3" custom exhaust from y-pipe to 4" tip using magnaflo muffler/10.2 alpine rear overhead dvd system
>>SIG IMAGE TOO LARGE<<
my2006titan is offline   Reply With Quote
FS: New Procomp 6" lift kit g356gear Buy/Sell 12 07-28-2006 04:59 PM
Going for the ProComp 6" lift! Titan1241 Titan Suspension 35 02-22-2006 07:32 AM
Anyone with ProComp 6" lift in LA? Galaxian Titan Suspension 23 02-15-2006 06:17 PM
ProComp 6" Lift tillery444 Titan Suspension 3 11-09-2004 03:45 PM
