Old 09-18-2006, 12:33 AM   #1 (permalink)
CST vs. Procomp
OK, i just bought a titan a few days ago, and now its time for the lift. Is there any large advantage of the CST 7" over the procomp 6" for the extra money it will cost.
And as i understand with the procomp i can use all stock shocks, but with CST i need to purchase extra parts as well.
Sorry if its a stupid question, i read everything here and still dont know.
ksport is offline   Reply With Quote
Old 09-18-2006, 05:27 AM   #2 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Re: CST vs. Procomp
they are both great kits. The only thing "extra" to buy with the CST kit is a set of rear shocks, the PC kit comes with rear shocks (worth about $50 if you were to add these to a CST kit). The CST kit requires cutting and welding where the pc kit doesnt. The CST kit provides a very nice swaybar end link where the pc kit is urethane mounted part (a step down from factory). Some ebay sites claim the CST kit can go back to stock, not without some welding and fab work. The CST kit includes an aluminum skid plate and uses 4" (instead of 3") rear blocks. The CST front will sit about 1" taller than the PC. you will loose a bit of turning radius with either kit but unless you grind the steering stops on the pc kit it will be an excessive loss. both can be upgraded later too.
Old 09-18-2006, 09:16 AM   #3 (permalink)
Re: CST vs. Procomp
I agree, my turning radius with my PC 6" is abolutely terrible. My wife refuses to drive the truck due to that alone. It is an '06 Crew Cab 4wd for reference.
Also, I have KMC Hoss 18" wheels on 35" Procomp AT Extremes and the 6" lift does not appear to be lifted 6". So, I would say that if you want your truck to look lifted like most other vehicles do with a 6" lift, than go with the 7" or 8" (I wish I would have). Hope that helps!
dcalderon is offline   Reply With Quote
Old 09-18-2006, 09:37 AM   #4 (permalink)
beached_titan's Avatar
Re: CST vs. Procomp
CST is including sway bar end links now? instead of a metal tube to cut and lengthen the stock end links? that kinda sucks. wish i would have gotten that with my kit if thats what they are doing. of course i kinda like the prg links...
beached_titan is offline   Reply With Quote
Old 09-18-2006, 10:33 AM   #5 (permalink)
rod_b's Avatar
Re: CST vs. Procomp
Grind down the steering stops. You'll never have the same turning radius as stock with any lift...especially if you've changed wheels and tires.
8.04 K11 CC LE 4X OR BT PRG'd
rod_b is offline   Reply With Quote
Old 09-18-2006, 11:53 AM   #6 (permalink)
jason27's Avatar
Re: CST vs. Procomp
Not to hijack this thread, but I didn't even know that you could grind down the stops. Someone help me get my turning radius back....thanks.
jason27 is offline   Reply With Quote
Old 09-18-2006, 03:59 PM   #7 (permalink)
Re: CST vs. Procomp
I sell sell the PC with the stops ground. as for the CST end links, we have them for $75 a set. You can make a pc kit taller than any other "stock" kit by just adding the proper coilovers. all current kits except the fabtech kit are a bit shy of thier claimed numbers (although the rancho kit is actually and inch TALLER than claimed). And the FT kit has its share of issues.
Old 09-18-2006, 04:40 PM   #8 (permalink)
jason27's Avatar
Re: CST vs. Procomp
what if you already have the PC kit on your truck?
Old 09-18-2006, 04:43 PM   #9 (permalink)
Aquaholic's Avatar
Re: CST vs. Procomp
The prg links are from cst.
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
RIVER TRASH C.O.R.R. Junky
Aquaholic is offline   Reply With Quote
Old 09-18-2006, 04:48 PM   #10 (permalink)
Re: CST vs. Procomp
So which kit would you recommend, for occasional off road use. But i do tow vehicles alot.
Old 09-18-2006, 04:48 PM   #11 (permalink)
Aquaholic's Avatar
Re: CST vs. Procomp
I love my cst lift. I wouldn't put anything else on my truck. After all the research I decided to do the best. I especially like the looks of it when you look at the sub frame from the front. Better looking then any other lift I have had, and I've had a few lifts, RCD(ford), Fabtech(toyota), Rancho(ford), Procomp(toyota), and CST(nissan).
Mods to date:
Old 09-18-2006, 05:18 PM   #12 (permalink)
i<3mytitan's Avatar
Send a message via AIM to i<3mytitan
Re: CST vs. Procomp
Ill agree with aqua. but take my word with some salt. this is my first true lift but I feel that what you get for the money is worth it. the subframe alone looks nice. additionally it comes with new UCAs although they could be upgraded. I was told cst has the best carrier bearing drop bracket, while producing a ride that is like stock. yes you'd neednew rear shocks, but for a true improvement in ride all shocks should be upgraded anyway.
No more sig for me
i<3mytitan is offline   Reply With Quote
Old 09-18-2006, 05:31 PM   #13 (permalink)
Yellomantis's Avatar
Re: CST vs. Procomp
Isn't the stage 1 procomp kit pretty much destruction proof with the deaver rears, rad flo coilovers, and good rear shocks?
www.myspace.com/yellomantis
Old 09-19-2006, 04:43 AM   #14 (permalink)
Chris93Si's Avatar
Send a message via AIM to Chris93Si
Re: CST vs. Procomp
I think I remember them claiming some of the components of the lift are bulletproff
When someone smiles at me all I see is a chimpanzee begging for its life.
My wheels for sale!
bustedshocks
P1 Auto
PRG
Chris93Si is offline   Reply With Quote
Old 09-19-2006, 06:06 AM   #15 (permalink)
goval's Avatar
Re: CST vs. Procomp
Question: Can you keep(if you already have) a 1.25" block with the Procomp Stage 1 shocks and a 2.5 Deaver Spring Helper? This set-up not using the ProComp's 3" blocks.
goval is offline   Reply With Quote
Procomp Coilover Canusaytitan Titan General Discussion 0 07-26-2006 06:55 PM
Procomp coilovers?? TitanOp Titan Suspension 2 06-27-2006 10:52 PM
Do it yourself procomp??And those Coilovers Case Titan Suspension 9 03-11-2006 05:30 PM
BFG All Terrains or ProComp ATs? EricCartmann Titan General Discussion 14 02-07-2006 06:15 AM
procomp lift kit? godofspeed Titan Suspension 0 03-28-2005 05:54 PM
