Old 09-21-2006, 02:02 PM   #1 (permalink)
pi3yeargrad's Avatar
Difference between pc carrier bearing drop bracket and CST bracket
Anyone know the difference between pc carrier bearing drop bracket and CST bracket? ANyone got pics of differences and instructions of both installs to compare? Greg tells me the CST is easier to install but both do the same job...He also says the the CST is more expensive... Any pics or info?
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 09-22-2006, 07:38 AM   #2 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Re: Difference between pc carrier bearing drop bracket and CST bracket
I will post pics on monday when i get back to the office. THe pc kit (fabtech looks just like it also) is about $40, the CST is $150. You need to cut the cross member on either set-up, but the cst one just drops onto the stock studs where the others require you to physically cut a factory stud at an angle and then drill a couple holes through the cross memeber then just installing the braket is a pain. The end results are the same though.
Old 09-22-2006, 11:19 AM   #3 (permalink)
oh cr@p ...so I prolly wont be able to this lift install by myself? U have to cut metal then for this bracket? Whats the cross member? Will I be able to install the front part of the lift myself at least? the spindles?
Old 09-22-2006, 11:07 PM   #4 (permalink)
I just did the CST drop bracket today and it took all of 10 minutes. Just cut the old piece out and install the new one. Greg (PRG) told me the CST is more expensive but much easier to install and it really was a piece of cake.
mluters is offline   Reply With Quote
Old 09-23-2006, 12:00 PM   #5 (permalink)
ye, thats what he told me...howd u cut? u think a reciprocating saw (saws all) would work? I dont have a torch or anything like that... what is the peice we have to cut? Any pics of that as well?
Old 09-23-2006, 08:06 PM   #6 (permalink)
Use a saws-all with a long metal blade and just cut out the old support bracket. Two cuts about 4 inches each.
Old 09-23-2006, 08:47 PM   #7 (permalink)
well hopefully someone can post pics so I can see exactly what this bracket is...
Procomp drop down carrier bearing kit for sale soanso Buy/Sell 4 09-09-2007 08:56 PM
Carrier Bearing Adjustment Kit? Tyltan Titan Suspension 7 10-02-2005 04:46 PM
I need stock Brake lines, carrier bearing bracket and A-arms whitetitan819 Buy/Sell 1 08-03-2005 07:44 AM
carrier bearing DaFridge Titan Suspension 8 07-03-2005 01:49 PM
Bed Extender Bracket? DALGATITAN Titan Parts & Accessories 2 01-22-2005 09:11 PM
