Re: Procomp stage 1 sag?
Two things could be casuing the sag. First, the spring itself is sagging. Not too common with stock parts, but it can certainly happen. Next is to check the alignment, if things have become toe-d out, thenthe front will sag when you drive. Double check the toe and see if its off.
