Old 10-07-2006, 04:23 PM   #1 (permalink)
6" procomp lift, 18" stock wheels, pc 35" xtreeme tire question
ive done my searching but cant find a clear answer. can i use the stock 18" wheels with procomps 6" lift and their 35" xtreme at tire which is 34.8 tall and 12.8" wide? i know people dont have problems with the bfg mt but this tire is a bit wider. will it rub the spindle? thats my only concern, bending back the pinch weld is np. anyone run a tire around this size such as toyos 35? mahalos
let your old age be childlike, and your childhood like old age; that is, so that neither may your wisdom be with pride, nor your humility without wisdom.
bighawaii is offline   Reply With Quote
Old 10-07-2006, 07:15 PM   #2 (permalink)
Aquaholic's Avatar
Re: 6" procomp lift, 18" stock wheels, pc 35" xtreeme tire question
Make sure you get the 35x12.5x18 not the 325/65/18. The 325 is 13.5 wide. You might want to look into the kuhmo mudds, they look awesome and I know for sure they fit with the stock wheels. The stock wheels keep the tires closer to the truck. The rims with backspacing that pushes the wheels out the side of the truck are what cause rubbing. For the kuhmos hit up SDTitan1, he has that setup on his truck.
2007 White with Charcoal/Titanium interior SE CC 4x4 with off road, tow, SE popular with bench, and utility bed package with sliding bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, SAW Racerunner bracket lifted 2.5" coilovers w/Eibach springs, PRGproducts UCAs, Rear SAW Racerunner 2.25" shocks, 325/65/18 Kuhmo Road Venture All terrains, 18x9 Moto Metal 954s, Stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, Rubber bed mat, 2008.5 Chrome grille, K&N 6012 , Custom FlowMaster DeltaFlow 50 series dual in single out muffler, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Infinity Reference 6 1/2's in rear and 6x9's in front, Infinity 1600a mono amp, (2) 1060W Infinity Reference subs, Prodigy brake controller, Ventshade door sill protectors
RIVER TRASH
Aquaholic is offline   Reply With Quote
Old 10-07-2006, 08:09 PM   #3 (permalink)
rgr, the 12.5" wide is what fits my 8" wide wheel, just was worried that the stock backspacing will cause the tire to rub on the procomp spindle. ill check for SDTitan1 thread, thanks
Old 10-07-2006, 08:22 PM   #4 (permalink)
hey thanks them kuhmos fit my wheels and are alot cheaper gonna read up on them.
Old 10-07-2006, 09:24 PM   #5 (permalink)
ok im back to wanting to get the procomp extreme tires, anyone with a procomp life and stock wheels with a tire with actual dimensions around 34.8 tall and 12.8 wide please chime in if they clear the spindle or not, thanks
Old 10-08-2006, 04:03 AM   #6 (permalink)
kartman's Avatar
It will probably fit with that lift but there are large variables, primarily the backspacing of the wheel. You may have to trim the fender liner and/or cut the pinch weld with the wider tire. I run Toyo 35s which are really like 13-13.5 with only 4 inches of lift but I cut the pinch weld, removed the liner and have glass fenders.
My best guess is that it will fit with very minor rub at full oick with no trimming and no rub with minor fitting, but its only a guess.
Rebar Wrangler
Old 10-08-2006, 10:00 AM   #7 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
The only spindles that have a clearance issue are the CST becasue they use a straight tube to make the spindle. All the cast spindles (stock, pc, ft, rancho) should clear that tire.
Old 10-08-2006, 04:54 PM   #8 (permalink)
thanks guys for the info, appreciate it.
Old 12-08-2006, 04:15 PM   #9 (permalink)
Hey prerunnerGreg. I want to make sure Im understanding you right? The only lift that you would need to run spacers with the stock wheel is the CST. If you get any other you dont need a spacer?
Ringold is offline   Reply With Quote
Old 12-12-2006, 07:32 PM   #10 (permalink)
coachflip's Avatar
Send a message via AIM to coachflip
I have the Nitto 325/65/18's on my truck and though they are close, they haven't rubbed at all. I recommend them, terra grapplers!
Brent
2004 CC 4X4 w/ProComp Stage 1
DR Coilovers/Bilstein Rears/TC Upper Arms
Deaver 1" pack w/3" block (5" rear lift)
CarPC with GPS/DVD/MP3/XM/Internet
eD6500's front
eD EU700's rear
eD 11kv.2's subs in upfire box
coachflip is offline   Reply With Quote
Old 12-13-2006, 09:49 AM   #11 (permalink)
i have the same setup that you are talking about. i have the Pro Comp lift with stock rims and PC Xtreme at tires 35 x 12.5. i have absolutely no rubbing issues on the spindle with this setup. i also have the radflo's from PRG, but that would not make any diff. with the tires rubbing the spindle. hope this helps.
JerseyTitan
2005 Galaxy CC Titan SE 4x4
Nissan Bugshield
Custom Flowmaster Exhaust (American Thunder Kit w/40 series Muffler)
Pro Comp 6" Lift, Radflo 2.5" coilovers, 2.5" Deavers, Total Chaos Upper A Arms, PRG Ofrroad traction bars, Injen intake, Airraid TBS, PA 3" Body Lift
Pro Comp 35x12.5x18 Extreme AT
JerseyTitan is offline   Reply With Quote
Old 12-14-2006, 11:13 AM   #12 (permalink)
kcchief_fan's Avatar
I have the Toyo 35's which are bigger than the procomp's on a 6" PC lift (w/ RadFlo's) and have no problem until recently when I lowered the RadFlo's to about 1/2" of thread showing (needed more travel and wanted softer ride) and I will hit when I turn at around a 45 degree angle hitting a 1 foot or larger "mound". I don't have the stock 18's but my offset is 10
2005 Crew Cab LE 4x4, Born on Date 5/05, Adopted 6/05/05, Smoke, OR/BT Packages, Sunroof, Nav System, DVD System
Mods: RETRAX Bed Cover, LUND SS bug deflector, AVS window deflectors, Covertech leatherette seat covers, ATS Fender Flares, LLumar ATR 15 CH SR HPR front side window tint, Valentine V1 radar w/ remote view, GTech RR, NAV speed sensor override mod, Power Tailgate Lock, SilverStar High Performance Halogen high/low bulbs, Injen CAI, Active Tuning Grounding Kit, ProComp Stage I 6” lift kit, Chaos Upper A-arms, Radflo 2.5” reservoir raised truck coilovers, PRG street traction bars, Deaver 2” mini-pack w/ 1" billet block, Bilstein 5100 rear shocks, CST sway bar extensions, Toyo Open Country M/T 35X12.5R18, Gear Alloy 711MB 18X9 off 10mm, Bassani exhaust, UpRev Tuner
Wish List: Bull Bar, Grill Insert, Clear taillights, Backup camera, Header, Stillen Supercharger, Tailgate chrome Bib, HID headlights, Amp Research Power Steps, Nissan Ipod controller, Larger crossdrilled rotors and ceramic brake pads, AVelectronics video switcher
kcchief_fan is offline   Reply With Quote
8" CST Nissan Titan Lift with 20"Rim's/Tire for SALE!!! ajaytitan Buy/Sell 1 05-23-2007 01:57 AM
Most agressive tire for stock 18", no lift or level. Ajax666 Titan Wheels, Tires & Brakes 9 01-19-2006 10:14 PM
Extra 2" on Procomp 6" lift. Tyltan Titan Suspension 9 09-20-2005 04:01 PM
Procomp Lift/20" wheels /35" tires Finkle Titan Pictures & Media Post 20 05-21-2005 07:59 PM
Procomp Lift Kit , Stock 18" Wheels Problems godofspeed Titan Suspension 15 04-14-2005 09:47 AM
