Are you planning to take the truck off-road or are you only after the look?
If you plan to take it offroad, avoid doing a body lift, at least that much of one. The body mounts act like levers and the flex from going offroad puts a lot more stress on the body, plus you'll find those pucks break relatively easily. Definitely don't want to cheapen up on the suspension if you plan to use it.
If you're only after the look and the ability to fit the tires, I don't see any problem with the body lift.
2005 Titan SE CC 4x4
2008 Dodge Grand Caravan SXT - Wifemobile
1993 Jeep YJ, heavily modded rock monster - FOR SALE - Buying a boat
I would suggest a cst 4" spindle lift and a 2" leveling kit. You will be much happier. Body lifts hurt your value and the toughness of your truck.
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
thanks alot- i knew there was a reason there was virtually no talk on the forum about body lifts. they are for show. i want to do a 4" lift to fit 35" inch tires on my stock 17" wheels. i want to start out spending as little as possible and then adding on as i can afford. how should i start. i want something strong that i can build on. do i do rancho lift, and then add better shocks and other parts? i have an 05 4x4 off road big tow. thanks again
As far as i'm aware of, if you don't want to spend too much right off the bat, either FabTech or ProComp is good to start with. Fabtech has more potential to go higher; ProComp has a better quality kit (from what i've HEARD). Yes, you can add better shocks down the road, at your own pace.
Rancho's another good kit, but i believe you need to use their shocks at the time of install (not too sure on this one, thoug)
This is my first post on this site, but Chris, in my experiences with modifying cars, trucks, etc., if you save a little longer, and get an entire setup together (ie - lift, shocks, a-arms, etc) at one time, you'll actually save money in the long run, and it will be alot less of a headache. Especially if you plan on doing the work yourself, believe me it's a pain in the *** to take stuff apart twice. I've had other vehicles that were "in progress" and it's just alot easier to change out a bunch of stuff all at once.
for you body lift haters go to the prg site and click on titan that smoke cc truck is 2wd with a body lift and that truck gets off road all the time and go's hunting from Oct-Jan and is full of mud as i speak how do i know its mine no body lift prob since 04 just show my a$$!!
As much as i really dont like body lifts (we dont sell or install them) they are not too bad at all on the titans. They still show less frame than a stock chevy!! Since the shifter and throttle are just wires, the brake and steering are all that are to be concerned with. As far as bodylifts go, these are probably the best trucks on the road to use one. I know desertdog and proarmwestler beat their trucks senceless and are both trucks are in great shape today.
