Re: Warning light after lift
On my last truck after having a lift installed I began to have the "ABS" and "brake" lights come on randomly. It ended up being that the way one of the ABS wires were routed to the hub caused it to get pinched. It was not pinched enough to give the visual appearance that it was damaged. After having the dealer diagnose the problem and replacing the wire the problem went away. After looking closely at the cable that was replaced you could see where it had a kinda flat spot in it, but the sheathing was not cut at all. Something to consider. I would try turning the wheels full lock to one side, get out and look at the routing of the line, then do the same with the other side as well. Make sure they are not being pinched anywhere.
2006 Titan LE 4X4 CC SOLD
SAW Coilovers @ 3.75" lift --FOR SALE--
Total Chaos UCAs --FOR SALE--
American Racing Mojave Wheels 17x8 --FOR SALE--
Goodyear Wrangler MTR 305/70-17
