extended brakelines possibly making noise
so i have the 4" cst spindle and 2.5" spacer. ever since i put it on ive been noticing a noise that sounds like it was coming from my antenna bouncing back and fourth while i drive so i took it off to see if that would solve the problem and it didnt so i was thinking that on my passenger side the brakeline sort rests on the bump stop off the frame while the drive side goes the opposite way around nothing so i thought it would be that it rests on the bump stop but when i bend the brakeline out it seems be in an "uncomfortable" position like it is bent in an unnatural way. not sure if that made sense but i hope it did cause thats the only way i can seem to explain it. hope someone can help.
