Old 01-19-2007, 12:37 PM   #1 (permalink)
Knocking noise, suspension?
I have a 2005 Titan 4x2 XE, 4dr, with stock suspension, but upgraded wheels. I seem to have a subtle knocking noise coming from the front driver's side wheel area. It doesn't take a big bump or pothole to make it happen though. I've been under the truck with a rubber mallet and can't reproduce the sound or find anything loose. The knocking noise is so subtle that if you turn on the radio, you can't hear it. Seems to do it more during cold weather. Failing shock??? Bad strut??? Truck only has 10500 miles. No apparent uneven tire wear either. It made this noise before I upgraded wheels. Anyone have similar knocking noise?
Fartloud1 is offline   Reply With Quote
Old 01-19-2007, 02:48 PM   #2 (permalink)
Gonpostal's Avatar
Re: Knocking noise, suspension?
I would guess it would be the sway bar had this problem on my old car.
Gonpostal is offline   Reply With Quote
Old 01-19-2007, 07:45 PM   #3 (permalink)
AETitan's Avatar
im gonna ask a question here since its basically the same topic, i dont have the knocking sound, but a high pitched squealing sound when going over a bump and turn at the same time, sounds like its coming from passenger front... i have cst spindle and leveling kit if anyone can figure it out.
another noise that i have thats non suspension related sounds like an antenna noise from it bouncing back and fourth with the wind but i took it off and it still made the noise, has anyone encountered this one, i have an extended cab 05 xe
AETitan is offline   Reply With Quote
Noise From Rear Suspension StuntDriver06 Titan Problems & Dealer Service 18 05-03-2007 04:13 PM
Possible Knocking sound? faith+1 Titan Suspension 12 07-01-2006 11:01 AM
Window making a knocking noise when lowered BLoch Titan Problems & Dealer Service 4 08-03-2005 04:03 PM
Clunking/knocking noise? virus Titan Problems & Dealer Service 0 12-04-2004 03:47 PM
