Old 03-06-2007, 07:06 PM   #1 (permalink)
BroncoAZ's Avatar
Bilsteins too long for stock?
I purchased a set of Bilsteins from a board member that he said he purchased from PRG and fit 0-3" lifted titans. I just installed one on my stock 4x2 SE and it appears that the shock is too long for my truck. The part number on both shocks is F4-BE5-6249-H5. Can anyone confirm if these are the correct application for a stock height truck or tell me what the application is? With the truck at ride height the shock has about 1.5" left of compression and the bumpstop is 3.5" from the frame. I'm sure the shocks would be bottomed out with a load in the bed. Any help would be appreciated.
Thanks,
Mitch
BroncoAZ is offline   Reply With Quote
Old 03-06-2007, 07:15 PM   #2 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Re: Bilsteins too long for stock?
Way too long, those are for 4" lifted applications.
Old 03-06-2007, 07:30 PM   #3 (permalink)
BroncoAZ's Avatar
Sweet, Anybody need a set of these in good shape? Looks like the seller and I miscommunicated on the length. Neither of us caught it in out PM exchanges. In reading his old posts he got the shocks with his 6" lift.
Mitch
Old 03-07-2007, 04:02 PM   #4 (permalink)
CDubya's Avatar
I sold these to BroncoAz. I purchased these from Greg and installed them with my Fabtech kit which had a 1" add-a-leaf and a 2" block. Greg, I asked you when I ordered them if they would work with that kit since it said 0-3" on the website, but maybe I misunderstood YOU. Sorry AZ, I didnt mean to mislead you. I thought there was only ONE bilstein for the rear since there was only one on the site.
2005 Titan 2wd Crew Cab Se
6" Fabtech Lift w/deaver pack-Total Chaos upper arms-braided brake lines-Rear Radlo reservoir shocks-Radflo Coilovers front w/ spacer-4" rear blocks-Prg traction bars-18x9 Moto Metal 950 wheels-Toyo M/T 35-12.50's-Street Scene Chrome Grille-Kenwood DDX7017-OZ Audio 180cs Matrix component set-2 Memphis MS 12" subs in custom Tech12Volt enclosure-Coverking seat covers, Amp Research Power steps, Flowmaster cat back...
Recently installed: Arc Audio 2100XXK amplifier on the top end and a Memphis Mclass 1000D amp on the subs-Optima Battery-Complete system rewire-Remote start.
CDubya is offline   Reply With Quote
Old 03-07-2007, 04:08 PM   #5 (permalink)
AgTitan06's Avatar
Bilstein 5100s are for stock height Titans, and Bilstein 5125s are for the lifted Titans IIRC.
Old 03-08-2007, 05:14 AM   #6 (permalink)
Not true. The 5100 (blue and yellow shocks) are typically a replacement shock from bilstein. The 5125 series (zinc plated body) is a performance upgrade, but they come in many lengths and valvings. The 5125 shock you would need is the 6248 not 6249. These are about 4" different in overall lenght, but the same valving.
New Bilsteins installed titan4life Titan Suspension 4 06-23-2006 08:51 PM
Yes!! I'm gettin my Bilsteins :) Howie Kaluha Titan Suspension 10 06-23-2006 08:49 PM
f/s bilsteins rear mytitan Buy/Sell 8 05-25-2006 07:47 AM
Solution to the Titan gas mileage problem…(long).. (very long) lowlypawn Titan General Discussion 35 01-18-2005 11:03 PM
Long trip with Titan, interesting stories... (long) bvstone1 Titan General Discussion 11 06-22-2004 09:57 AM
