All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
has anyone lifted a titan and put 24'' with mud tires? i have 24s already i am just kinda curious how high to lift it to fit the mud tires..
with 24s, i would imagine you'd have to run at least a 40" tire...so 15" + 3" bodylift
problem now isn't how high to lift it, but if the tranny can sustain that kind of abuse to turn wheels w/a ton of unsprung weight through some thick mud....
A while back there was a tour vehicle for Papa Roach for sale on here. It had 9" of lift and ran at least 22s. It looked pretty insane. As far as really "off-roading" with that set up, I don't really know what to say. Good luck, post some pics if you get it done, I'd definitely like to see it.
Saw an article in Petersen's 4 wheel-offroad not to long ago doing a comparison of offroad ability on some 20's and 16's. The 20's had less off road ability due to more surface area for bending on rocks, less tire cushion, and not as much ability to be aired down.
I'm assuming your not really wanting to take some shiny 24" off road though, so more power to you. Post a pic when you get them.
15'' rims 4 mudding whats the diff .. other then i can afford 24''s
For one, a 15" rim wouldn't even fit on a titan let alone a 16". And since you've obviously have money coming from daddy with little knowledge on how to do things right, I've got a brilliant idea. Why don't you throw some 26" dubs on there with some low profile tires and go offroading. And if something goes wrong, don't worry, you have all kinds of money to fix it.
There's a reason why the offroad package has a smaller rim size then your standard. Larger rims aren't meant to go offroading unless you've got quite a lift to compensate for the larger tire diameter.
Ignorance and stupidity usually go hand in hand, and congrats, you're not exception. Also, I love the way you spelt "suspention". Brilliant!!
Go for it... I would love to see it... You could do the lift that I have with a 3" body lift and clear those 38's easily...
05 CC Le 2wd in Radiant Silver, Fabtech 6" lift, Radflo external resevoir coilovers and spacer, TC arms, 3" deaver spring pack, 4" tapered block, color matched powder coated traction bars, 20" KMC Jacks and Five wheels and 37x13.5x20 Kumho MT's, Big tow package, Speed grill, custom painted engine cover and tailgate bib, LED third brake light, Truxedo Lo Pro, 15% tint on front windows, 50% on the windshield, Fram Boost intake, Warn bug shield, Color matched Bushwackers, color matched headlights with 8,000K HID's, (1) 12" memphis sub in a custom made ported box by Tech12volt and a JL 500/1 pushing the 12....
