Re: Giddy As A Schoolboy
Well, from what I've read on this site as well as others, you can easily fit 35's on your truck with just a 2 to 2.5 inch leveling kit. It depends on the backspacing of the wheel you upgrade to. I'm curious though: Are you sure of the dimensions of the tire you specified? 315mm = 12.4in. The tires you're considering might be 325mm, which would be closer to 12.7in (12.8in rounded). I'm not sure that it makes a difference. I'm relatively confident, though, that you would be able to fit the tire with the Performance Package no matter what the exact width is. I would ask around here and make sure you get a wheel with the right backspace value. You might still have to do the pinch weld mod, remove or reshape your fender liners, and remove your mudflaps (if you haven't already).
With respect to the preload on the SAWs, Greg said that 3in of lift seems to be the sweet spot. You start having problems when you exceed 3.5in, at least with a 4wd. That's fine by me. I'm interested in function more than looks. But honestly, I think your truck would look great if you decided on just the Performance Package. Although it would look pretty slick with the glass fenders and the MT kit! I'm not sure what I'll do. I want to play with the Performance Package a bit and see how it handles. I guess it depends on how hard core you are. I myself am little reluctant to fly in my daily driver!
