Old 03-09-2007, 07:50 PM   #1 (permalink)
a few questions
i have a cc with the cst 8inch lift with dr coilovers and the uca's hit the shock tower at full down travel, will the total chaos uca's get rid of this issue, if not what due i do about it?? also are there any ways to lift the front end up a little higher?? ok the last question, i want fiberglass front fenders and the ones i like are the glassworks, were do i get them in socal and how much sanding etc... will it take to get them to fit perfect??
crftitan is offline   Reply With Quote
Old 03-09-2007, 08:30 PM   #2 (permalink)
SmokenMini's Avatar
Re: a few questions
The TC UCA's will help but won't totally eliminate the problem...at least with my experience.
2005 Smoke CC BT OR
ProComp Stage 2
PRG Leveling
Deaver Full Spring Pack
Total Chaos upper arms
20" Moto Metal 951's
36/13.50/20" Irok Radials
Husky Liners
Lund Stainless Hood Guard
Lund Tri-Fold Tonneau
Rear diff's be ware....I will break you
Because lifes' too short to drive an ugly truck...
SmokenMini is offline   Reply With Quote
Old 03-09-2007, 09:20 PM   #3 (permalink)
Yellomantis's Avatar
Re: a few questions
Glassworks claims they will fit perfect without any heavy shaping at all. They claim to have re done their mold recently to fix all the problems they were having with the old fenders. You can get them from Kartek in Corona or from Glassworks direct. The owner has a TITAN. In fact, that's his black TITAN in the pics of the fenders and bedsides.
I was planning on getting the Glassworks fenders, but I found a set of Hannemans for $200. They need A LOT of work though. Major fitment issues here. But I will just be scratching these up anyways, so I will be buying the Glassworks eventually.
2006 4X4 LE OR CST 7" Lift, RadFlo 2.5 coilovers, PRG Uppers, RadFlo 2.0 rears, Deaver 2.5 mini pack, 3" custom block, PRG traction bars, TC HD rear shackles, 2* advance, Custom Supertrapp exhaust, XE mirror covers and door handles, 17X8 AR Mojave Teflon's, 35/12.50R17 Toyo Mud Terrains, Bushwacker fender flares.
www.myspace.com/yellomantis
Some more questions sjorengray Titan General Discussion 11 01-30-2007 10:39 AM
new guy with questions moosehunter Titan General Discussion 4 01-09-2007 10:08 PM
Two questions? titanmike Titan General Discussion 5 09-07-2006 08:11 PM
some sub questions YZmoto125 Titan Visual & Audio Discussion 3 04-13-2006 03:35 PM
2 Questions. jpup Titan Wheels, Tires & Brakes 5 06-30-2005 12:11 PM
